Author Topic: a few abf questions  (Read 5712 times)
Re: a few abf questions
« Reply #10 on: 31 December 2008, 10:31 »
i dont think they change the height at all, its just the ABF mount is a beefier design.  Looks like it probably does go into F/9 then, check for continuity between that wire and pin 22 on the ecu plug :)
how are you planning to run your rev counter by the way, the ABF ecu signal wont work with the MK2 clocks.  You can open the ABF coil and splice a wire to one of the terminals, or chop it out and run a MK2 coil instead.
Offline danny_p
« Reply #11 on: 31 December 2008, 13:52 »
have done pinouts if you want copy just drop a pm
all the VW's have gone bar 1.
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
« Reply #12 on: 31 December 2008, 14:27 »
Gone down the easier path of using the mk3 clocks and coil. Can't face any more work!!. maybe further down the line ill run the mk2 ones. Have just dropped the subframe and the rear mount bolt has popped out the top so its now in 2 halves, the thread has stripped. don't know how long it has been like this for.
Danny you have pm
« Reply #13 on: 31 December 2008, 14:40 »
cool, defo want to check that wire out then!  I'm pretty sure its F/9 for the rev counter now, but you really need to check where the other end is before we can be sure :)
« Reply #14 on: 31 December 2008, 20:46 »
Another quick question as the toledo should hopefully be gong to the scappy in the next few days. Where abouts it the diagnostic socket. Is there one? :undecided:. Thanks alot
Offline danny_p
« Reply #15 on: 01 January 2009, 17:25 »
cant rember  but the wire for it is the green one out the immob box
« Reply #16 on: 01 January 2009, 17:41 »
ok ill have a look tomorrow, danny p did you have any joy with those wiring diagrams  :smiley:
« Reply #17 on: 02 January 2009, 09:35 »
it'll be behind one o the dash blanks, or perhaps behind a panel next to the ashtray once you open it easy to find though follow the yellow, red/white & grey/white wires, or follow the immobilisor box wires if it has one.
« Reply #18 on: 02 January 2009, 10:07 »
All i can find is this which i recall was behind a dash blank next to the steering wheel? Its not connected to anything now though  :sad:
Will it matter if i don't use it  :undecided:
Offline danny_p
« Reply #19 on: 02 January 2009, 10:28 »
find the green wire  and tape it up to something so you can find it at a later date  but it's not required,
