Author Topic: Air vent boost guage  (Read 1823 times)
Offline plowy
« on: 29 December 2008, 22:44 »
have seen some people have the air vent boost guage on the drivers side which looks damn cool, for those of you who have it whats involved in the fitting/wiring up of the guage...
Offline Hurdy
Re: Air vent boost guage
« Reply #1 on: 30 December 2008, 01:16 »
Both RedRobin and Joesgti have boost pods. Joe fitted it himself and so is probably the best one to ask. :smiley:
Seat Leon Cupra Black 290 DSG
Offline john_o
« Reply #2 on: 30 December 2008, 08:56 »
or maybe even http://www.golfgtiforum.co.uk/index.php?topic=68927.0  :grin:
fitting depends very much on the guage type.
For the DEFI you route only electrical wires through to interior (as the seperate sensor converts air pressure to an electrical signal under the bonnet)
For other guages you route just a boost line (air) through to the interior
Both will take live/earth and illumination from inside the car (fusebox)
hth
John
Black 3dr Edition 30 manual
DEFi boost gauge | ECS Dogbone | WLineAntiLiftKit
Offline plowy
« Reply #3 on: 30 December 2008, 23:12 »
Thanks, just had a look at the SWG one, it aint bloody cheap !!!!! :shocked:
Offline neg
« Reply #4 on: 01 January 2009, 19:17 »
Looks OEM ... not much others on the market to choose from though
Offline Toast
« Reply #5 on: 01 January 2009, 19:34 »
I've got the Swg boost gauge in the edition 30 looks Very oem and tidy just got to wire it in now :smiley:
Vw all the way!!!!    'Oot n By'
2007 3dr Tornado red Edition 30, Giac remap with flashloader 321bhp 300lbsft torque,Miltek Catback,Carbonio intake,H+R 30mm springs,s3 cooler,Swg Boost Gauge  Coming soon - Hp fuel pump,Porsche 997brakes,Pelequin Diff,Sachs uprated clutch
Offline joesgti
« Reply #6 on: 02 January 2009, 14:58 »
15 min job, piece of p!ss, and looks coool  :cool:
GTI MK5
Not the only GTI...........but the best! ; )
Offline plowy
« Reply #7 on: 02 January 2009, 22:08 »
is there somewhere that shows...
Offline LaserBlue
« Reply #8 on: 02 January 2009, 22:14 »
lol if your on about fitting a boost guage you must be wrong? i rang up awesome for a quote and they said around the £400 with labourmark as it takes upto 3hours to fit correctly as they have had problems later on with installs going wrong.
they said something about removing interior parts and routing wires so they dont get damaged or worn down plus placing it in the correct place??
i could be wrong as i have not done it personaly.
Offline neg
« Reply #9 on: 02 January 2009, 23:59 »
I would say it took me no more than an hour once I worked out what I was doing.  The route for the pipe took a while to figure out and obviously I was careful not to damage anything.
Having the forge DV makes it easier too as you can use the second take-off on the valve which the DV uses.
