Author Topic: Need help with wheel size!!!  (Read 2994 times)
Offline cabbywothers
« on: 27 December 2008, 20:30 »
hi whats the widest wheels i can fit on my mk3 golf been looking at 8x16 with a 195/45/16 what mods would i need to do
Offline shepgti
Re: Need help with wheel size!!!
« Reply #1 on: 27 December 2008, 20:55 »
would have to roll the arches
« Reply #2 on: 27 December 2008, 21:10 »
If the offset is around et35 and your not too mad with the lowering they should go under a standard arch.
Offline LostBok
« Reply #3 on: 28 December 2008, 21:42 »
Not sure if this helps with your calcs: but I'm running wider TYRES than that right now (205mm / 45 profile on 16" wheels)... and that's on 7j 6.5J wheels with an ET45 offset...
That wheel is about 10mm narrow that it ought to be... so the car DOES look pinched (as in "too narrow" - not "stolen" ;) ) - and that's why why I'm fishing around for help with spacers.
« Last Edit: 14 January 2009, 19:52 by LostBok »
LOSTBOK
Audi A4(B6): 2.5TDi Quattro Sport: Factory fitted Xenons, BOSE, and full sports leather "Soul Black / Titanium".
Mods: All OEM: S-Line bodykit, RNS-E, Bluetooth, Audi R8 FBMFSW, SDS-High voice control, full DIS, cruise control, Aero wiper mod.
In progress: 5 x OEM S4/Ronal 'Avus' 18's & 235/45ZR18 Toyo Proxes T1-R (bah! wheels delayed until WC 27-JUL-09)
Researching: Colour DIS, Freeview and DAB tuner with iPodvid/PSP/AV in for the RNS-E.
Offline spunkymonkey
  • Tepidly moist! That's what that is!
« Reply #4 on: 28 December 2008, 23:23 »
I run 8x16 with a 195-45-16 and unmodified arches. Its lowered 70mm and doesnt really catch. The offset is ET22 aswell. They will fit!
Offline MK3TDi1996
« Reply #5 on: 14 January 2009, 11:00 »
hello all,
I've got a set of team dynamics omega wheels to go on mine - it's a 96 TDi mk3.  I intend to fit 205/45/17 - are they gonna go on no problem? ie, not catch or rub?
I will be buying coilovers too so what sort of drop can i achieve without running into any problems with these wheels/tyres?
Thanks
« Reply #6 on: 14 January 2009, 11:46 »
hello all,
Thanks
You need to make sure the offset is et35 / et37, 205/40/17 is the correct tyre size and you could lower it around 40mm, any more then that and you will need to tweak the arches.
« Last Edit: 14 January 2009, 11:48 by wayned »
Offline MK3TDi1996
« Reply #7 on: 14 January 2009, 15:20 »
hello!
thanks for the reply sorry but being a newbie and all - how do i check the offset?  Also, will 205/45's not do?
Thanks
« Reply #8 on: 14 January 2009, 15:56 »
hello!
Thanks
Offset is stamped inside the wheel, no 205/45/17's are the wrong size, they will throw your gearing out plus being bigger could lead to rubbing issues.
« Reply #9 on: 14 January 2009, 15:59 »
hello!
Thanks
As well as looking a bit naff!  :smiley:
