Author Topic: knocking noise  (Read 1654 times)
Offline muppet
  • 1.8 16v Oak Green :D
knocking noise
« on: 27 December 2008, 00:33 »
hi guys bit of a problem......
ive just gone through a few of the other posts but nothing seems similar to what im getting
i hear a loud knocking noise when i pull away pretty much every time in 1st and sometimes in 2nd.....
ive had a mate check the balljoints and he says theyre fine im waiting until monday to take it to kwik fit to make sure it aint the exhaust or when i get the clocks back in!lol
is there anything else i need to check for? thanks guys
Offline mattkh
Re: knocking noise
« Reply #1 on: 27 December 2008, 09:09 »
Hi
Check the engine mountings.
Offline DarnPB
  • Formerly Darnpistonbroke
Re: knocking noise
« Reply #2 on: 27 December 2008, 11:00 »
As above. Check the front engine mount, then check the CV joints, although the CV joints will be more noticeable on full steering lock. Ball joints will be more noticeable on a rough road, gravel or over speed bumps.
Once you have discounted the above, look at thefront shck mounts. if the upper bearings are worn and dry, you will get some degree of knocking too!
Offline muppet
Re: knocking noise
« Reply #3 on: 27 December 2008, 17:38 »
thanks guys ill have a look into it on monday when im not working!!! will keep you posted
while im not doing it until monday..... anyone else got any more suggestions lol keep me busy on monday :smiley:
just come to think of it I ONLY GET ONE KNOCK!!!!!!!
« Last Edit: 27 December 2008, 17:47 by muppet »
Offline sparkplug
Re: knocking noise
« Reply #4 on: 27 December 2008, 20:49 »
I woudn't trust Kwik fit to put air in my tyres.  :angry:
mate go to a real garage .
1986 GTI atlas grey
Offline filthy
Re: knocking noise
« Reply #5 on: 28 December 2008, 11:57 »
Strut top mounts...I had the same problem, went through replacing engine mounts etc...turned out the top mounts were knackered....cheap fix as well  :smiley:
Having trouble keeping it on the straight and narrow?  www.powersteeringstore.co.uk
Offline muppet
Re: knocking noise
« Reply #6 on: 28 December 2008, 17:47 »
cheers for the help guys im gonna take the car to my mate 2mo and see what he can do!!!  :grin:
Offline muppet
Re: knocking noise
« Reply #7 on: 03 January 2009, 00:34 »
taken my time to reply to this one!!!
but it was the top mounts ........
just wanted to ask would it be any different if i put in g60 top mounts? relativly the same price so might aswell  :huh:
Offline DarnPB
Re: knocking noise
« Reply #8 on: 03 January 2009, 03:31 »
G60 top mounts fit fine and are a little more durable than standard ones.
