Author Topic: intake manifold / fmic Q  (Read 3144 times)
Offline turbokid23
Re: intake manifold / fmic Q
« Reply #10 on: 28 January 2013, 18:08 »
Sort to put this on here but I have every think you need if u want to do the s3 look pm me if ur intrested
Offline Dalo Harkin
« Reply #11 on: 28 January 2013, 22:28 »
well for a start did you have to modify the charge pipe to be able to fit how did you connect to the turbo
and did you have to modify the fuel rail and extend any wiring??
[/quote
no didn't modify charge pipe, used the old tube that went from old smic to throttle body, standard fuel rail and all you have to do is unwrap the wiring from the loom and then 're wrap when pulled to passenger side I' 'll try and get some pics tomorrow
Offline Dalo Harkin
« Reply #12 on: 29 January 2013, 13:14 »
I removed all the silver stuff over the charge pipe, I was working on the car and by god does it get hot  :shocked:
Offline cooki
  • 1.8T AUM
« Reply #13 on: 29 January 2013, 14:20 »
I routed my toyosport pipework under my tip/induction kit on my aum gti when fitting my front mount.just needed to exstend some hosing for the dv and n76 take off.ill try get a pic up for u asap.
Had to cut a pipe or 2 of the intercooler pilework dwn slightly bit it worked well and is tucked in nicely.
1.8T AUM,18"s,full koni suspension kit,forge split r on fully recirc,k&n induction with cold air feed,FMIC,r32 front,colour coded rear valance,black front and rear VW badges,5 door wind deflectors,boost gauge an volt metre in A pilla pod,full brushed alluminum net optic interior,full creame heated interior,
PLANS: catback exhaust&remapp her  :) :) :)
Offline golf-sib
  • Турботазик
« Reply #14 on: 30 January 2013, 18:09 »
Mine runs under tip, just don't go to low otherwise you get in the way of the gear link arm, all my pipes are heat wrapped as well so you don't notice them.
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
