Author Topic: Outside temperature sensor  (Read 1871 times)
Offline squeakyduck
« on: 13 January 2013, 18:21 »
Where is the outside temperature sensor located?
I noticed that on my 8v gti the temperature reads -25!! Would a new sensor cure this or do you think it could be another issue?
Offline spikenipple
Re: Outside temperature sensor
« Reply #1 on: 13 January 2013, 18:32 »
It's on the off side bumper grille. Can't say I've seen that issue before!
Offline murraymint
« Reply #2 on: 13 January 2013, 18:35 »
Mine was reading 18 last night  :laugh:
josh
Offline squeakyduck
« Reply #3 on: 19 January 2013, 14:40 »
Its all over the place at the moment. In the snow it changes from between -25 and +10!!
Does anyone have a part number from VW? I had a look online and the only thing I can see it thermostat sensors!!
Offline itavaltalainen
« Reply #4 on: 19 January 2013, 14:47 »
Jumping from one temp to other might indicate that you got moisture in the plug....
Did you bump into a mountain of snow?  :whistle:
Would check that first, if you still want to replace it is 357919379A
