Author Topic: What's the best 1.8t engine to go for?  (Read 5444 times)
Offline rockmonkey69
Re: What's the best 1.8t engine to go for?
« Reply #20 on: 28 April 2012, 12:39 »
I agree with the above, it is better to buy a 20vt golf to begin with than to convert unless you plan to rebuild the engine. For one, there are many advertised 'engine conversion packages' for sale now and not just on eBay, theres no guarantee the engine is as advertised, if one was to install an engine that was advertised as having 48000 miles only to find it shows 110000 miles on the clock after all that work of doing the conversion there's few who would take it all back out again, strap it to a pallet and arrange for pallet line to collect it. This is a very real scenario and it has actually happened to myself before but the engine was intended for rebuild from the very start so wasnt so much an issue.
Although no one is saying not to do the conversion we are advising against it or to approach with caution and extra budget because of all the headache and possible problems. There are a whole host of other things that you should consider not least the possibility of getting a non runner, an engine with mechanical problems, work valve stem seals? Piston oil or compression rings, bearing issues, seized tappets or just dead, all entirely possible when you consider the 20vt engine from its infancy is now well over 10 years old! Buying a 20vt golf means you can test drive it for more than just a few minutes to make sure everything is good. Today you can pick up a 20vt golf for not much, so you really have to ask yourself if it's really worth it.
Offline xtetx
« Reply #21 on: 28 April 2012, 12:51 »
There is a lot on this thread to consider, thanks a lot guys!
 :laugh:
Offline shaft69
« Reply #22 on: 28 April 2012, 13:57 »
I need to get it on some difrent rollers.. The chassis kept touching the floor when lowering it down on the rollers.. Pluss by the time he got the Saab Injectors mapped in he said I was running really hot..
But.. It got 210bhp and 249 lbsft holds the torque through most of the revs.. Pulls really well quicker than my mates scoob and mate mk1 focus rs and his is running 240
Really impressed with it.. Was gutted about the figures but when I drove it it soon changed.. Feels awesome, like I said I've still got the meth kit to fit yet also :)
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline shaft69
« Reply #23 on: 28 April 2012, 13:58 »
"gti-boz" Should be way past that once set up right be looking 240ish plus anther 15-20 bhp with meth. Mine was 218 with meth off 231bhp with meth on have interior switch to turn on/off. Want snow meth digi controller to control system just pretty expensive but it will come
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline gti_boz
« Reply #24 on: 28 April 2012, 14:37 »
Yer t is strange as my mate has similar figures on his mk4 and he hasn't done half the work I have.. Leaves his for dust aswell that's why I was confused with the figures and performance
