Author Topic: Pollution filter location? / blocked air vents??  (Read 1968 times)
Offline Cosworth Lee
« on: 14 December 2008, 14:02 »
Can anyone tell me where the pollution/pollon filter is, im guessing its either under the scuttle panel or accesable from the inside under the dash?
My demisters are not working too well and the air con is nearly non existant.
And as you can imagine this time of year its not ideal as its hard to stop it demisting
just wanted to check the filter first hopefully this is the cause, but dont know where it is  :grin:
Offline Rhyso
Re: Pollution filter location? / blocked air vents??
« Reply #1 on: 14 December 2008, 16:05 »
just a reminder that your air con won't work when the outside temperature is under 4.0 C so thats a possible reason why you think its non-existent
Offline stealthwolf
« Reply #2 on: 14 December 2008, 17:12 »
really? why?
Offline Rhyso
« Reply #3 on: 14 December 2008, 18:05 »
really? why?
dunno - i know in my MKIV the air con won't work under that temperature and have assumed its the same case for the MKV  :undecided:
really fecking annoying tbh
Offline Komenda
« Reply #4 on: 14 December 2008, 18:22 »
really? why?
It cuts off as the unit will freeze, and then you are fooked
« Reply #5 on: 15 December 2008, 17:38 »
Nope its been like it since i got it in june!!
As far as im aware you should be able to use aircon all year round, It even says in the manual it can used in the winter with the heat also on as its a very good demister/ dries the air!!
So anyway its not that.
So no one knows where the polloution filter is then. lol  :grin: :sad:
Offline bacillus
« Reply #6 on: 15 December 2008, 19:41 »
iirc you have to look under the dash on the passenger side for the filter.
Without traction power is nothing!
