Author Topic: khare's mk3 GTI...16v!  (Read 246123 times)
Offline VR6_Wherry
Re: khare's mk3 GTI...16v!
« Reply #490 on: 20 January 2011, 10:43 »
Why not have the inlet manifold polished  :cool:
Loooooooooads of effort as Wherry has already pointed out. I tried to polish the cam cover on the 8v and no way I'm trying it again!  :laugh:
Won't be done before JKM wherry, infact it probably won't be done until summer time  :grin:
Lazyness, that's terrible! i'm polishing my turd up to give it a proper shine!
Offline Khare
  • The bear that khares
« Reply #491 on: 20 January 2011, 10:46 »
Jetwash at petrol station for me, no time for fanning about  :grin:
Offline Khare
« Reply #492 on: 03 February 2011, 16:19 »
Well yesterday I got in the car, only to find it wouldn't start (moisture inside distributor cap again), so I got it going with lots of WD40 again and limped to GSF where I got a new cap and rotor. Fitted that, and it improved by a lot, but it still had a slight misfire on the way back on the top end (fitted it at the GSF car park  :grin:). Got home, removed old plugs and  :shocked: No pics but they were absolutely gone! The electrodes were almost worn completely out. Fitted some nice new NGK plugs and now runs sweet as a nut! No problems whatsoever on my way to Gatwick airport.
So one issue sorted, the next mod was on the list, the 16v brakes.
Gave them a quick wire brushing the other day, but I wasn't very happy so I got the drill wire attachment today and gave it some of that. Got them nice and shiny again and rust free  :smiley:
Also gave them the traditional Khare motorsport paint colour scheme  :grin:
Mintex M1144 pads arrived today too, and I already had the goodridge braided brake lines  :smiley:
(Ignore GT5  :grin:)
Disc wise, I'd like to get something fancy with holes and grooves but I've run out of money for a while. I've got the standard 288 discs in the shed which I may stick on while I save up for better ones.
 :smiley:
Offline Dan34
  • VTEC Powerzzzz
« Reply #493 on: 03 February 2011, 16:29 »
Looking good.
But dont get disc's with holes, there pointless. 6 groove discs ftw!
Offline VR6_Wherry
« Reply #494 on: 03 February 2011, 16:31 »
Bright Yellow then! :cool:  :grin: :grin:
Offline Khare
« Reply #495 on: 03 February 2011, 16:32 »
Indeed  :cool: :cool: :cool:
Offline SoundillusioN
« Reply #496 on: 03 February 2011, 19:31 »
Good little bit of progress.... when the hell did you last check you plugs then!?  :shocked:
Offline Khare
« Reply #497 on: 03 February 2011, 19:33 »
Hadn't checked them on the 16v  :laugh:
So minimum 1 year old plugs, they looked more like 10 year old though  :grin:
Offline Khare
« Reply #498 on: 03 February 2011, 19:43 »
I've just spend 5 minutes trawling though the food bin to find the plugs  :sick: :sick: :sick: :sick:
Sorry for the bits of food you may find  :sick: :sick: :sick: :sick:
Offline Khare
« Reply #499 on: 03 February 2011, 21:16 »
Up to date to do list
•   Rear number plate light
•   Locking wheels nuts
•   Adjust drivers door
•   Clean throttle body
•   Drill air box
•   Full wet-vac clean inside
•   Full outside clean, wax and polish
•   Replace bumper air vents with cold air intakes
•   Fix outside air temperature sensor on MFA
•   Replace:  Spark plugs
                 Oil and oil filter
                 Distributor cap and rotor
                 Air filter
                 HT leads
•   Fix sunroof
•   Fit new speakers
•   Red GTI front badge
•   VR6 front splitter
•   Wire hazard lights to alarm
•   Buy and fit hella quads
•   Align hella lamps
•   Spray VW badge black
•   Fix windscreen washer bottle
•   Fit poly bushes, new ball joints and new top mounts
•   4 wheel alignment
•   Fix water leak from the front head flange
•   Install new steering rack
•   New gearbox mount
•   Gearbox oil service
•   Polybush rear beam
•   Fix oil cooler leak (O-ring)
•   Replace both door mirror covers
•   Replaced heated glass on driver's side door mirror
•   Replaced blown rear left 6x9
•   Waxoil underneath
•   Upgrade brakes to 288mm
•   Paint brake calipers
•   Touch up scratches
•   De-cat
•   Coilovers
•   Gearbox alignment
•   Fix slow puncture in OS front tyre
•   Full interior strip
•   Wash carpets
•   Disinfect
•   Fit new soundproofing
•   Fix all creeks
