Golf mk2
Sunroof Seal?
Topic: Sunroof Seal? (Read 1933 times)
16v Matt
Here all the time
Sunroof Seal?
11 June 2004, 12:53 »
Hi everyone, my sunroof seal has started to come away. As it only slides i can't get my big fat hands under it to push it back into place. How easy is the sunroof to take out so i can repair the seal? Or do i need to pay someone to do it???
Cheers,
Matt
www.dubcircle.net
VeeDubGTI16v
Guest
Re:Sunroof Seal?
11 June 2004, 13:52 »
fairly easy to get in and out, you just have to push down on the sunroof as you remove it because if you just pull it you will scratch the sunroof on the roof. and you might have to fiddle around a bit getting it perfect when putting it in again.
16v Matt
Here all the time
Re:Sunroof Seal?
11 June 2004, 15:44 »
Cheers for that, i'll give it go!
www.dubcircle.net
VeeDubGTI16v
Guest
Re:Sunroof Seal?
11 June 2004, 17:49 »
try and mask the whole sunroof panel if you can be arsed, or use a towell/dust sheet. i say this cos i scratched mine :-[
p.s. try and get an extra set of hands, one either side of the car it will be a lot easier
Golf mk2
Sunroof Seal?
