is the only way to describe how I feel.
If you're not familiar, I didn't have antifreeze and everything froze up. I've replaced the metal pipe, changed the radiator, charged the battery and bought and fitted a new starter motor....and I go to turn her over and ... NOTHING!
Here's what I know,
- The fuel pump is priming and the pressure is ok
- Compression is even 12bar across all 4 cyl
- Spark plugs are clean and there is a strong spark
I had gotten it to run once, but it wouldn't idle, it only kept going if you kept it on mild throttle.
The rest of the time when you crank it, after about 6/7 seconds theres a loud bang from the exhaust - almost like a backfire, but the exhaust is cold.
Interestingly when I took one of the spark plugs out to test the spark, it did bang and there was a light smoke coming out the spark plug hole.
The car has been sat stationary for almost 5 weeks - and I believe the valve stem seals leak, so its likely the cyl were full of oil? And I can only guess the bang was hot carbon deposits igniting fuel from a flooded engine?
The only thing I can think is that the timing could possibly be out from ice expansion - but its a long shot. What's going on!
Edit More googling has revealed it could be a vacuum leak, or moisture in the dizzy - so I'll check those in the morning.
