Author Topic: How easy/hard to fit a complete mk2 gti wiring loom?????  (Read 1157 times)
Offline dubstar81
After many running problems with my k jet conversion i have decided to replace the whole loom. The car was originally a digifant. I am planning on fitting a comlete K jet wiring loom.
All the old wires are almost out so looking quite bare.
How easy or is it to fit?
Or how much would it cost for someone to fit it for me?
Please help :cry:
Offline nealey
Re: How easy/hard to fit a complete mk2 gti wiring loom?????
« Reply #1 on: 09 December 2008, 21:13 »
inside etc is all fairly easy once you have the seats, carpets and trims out
engine loom reqs the servo to be taken out as the loom goes behind it
Offline dubstar81
« Reply #2 on: 10 December 2008, 07:41 »
Sounds pretty straight forward.
Seats, and carpets are already out.
How do i get the dash out?
There seems to be a few hidden ones that i cant see.
« Reply #3 on: 10 December 2008, 07:55 »
Quick question, why did you switch from digifant to k-jet.
« Reply #4 on: 10 December 2008, 08:35 »
dash is held in with 2 bolts either side, 2 bolts underneath either side of centre console, and 2 nuts under the plastic scuttle cover in engine bay.  You need to take the dash switches/blanks out, heater knobs & panel, plastic switch/clocks surround, clocks then finally the dash will come away.  Take care dragging it forward, there is some wiring loom clipped above the fusebox, the glovebox light will be attached if it has one plus dash speakers if any are fitted.
Offline dubstar81
« Reply #5 on: 11 December 2008, 13:11 »
Cheers guys.
Reason for doing the conversion is that my old k jet golf was a 2.0l with a 4+e gearbox and i had to scrap it. So i thought it would be a cool idea to swap it over. A bit different from the norm + i didn't want to spend loads o money re mapping the digi ecu.
« Reply #6 on: 12 December 2008, 12:34 »
To be honest the digi system would have coped ok with the 2.0, it has a higher limit than k-jet which can be very limited at higher revs in terms of air flow of fuel delivery.
