Author Topic: speedo and heater went dead lights wipers all dead.  (Read 3148 times)
Offline so1o
Two problems in one day. I was on the motorway sitting comfortably at 80 when i see the speed needle drop to zero.
Second problem is my heathers are knackered. Does not work at all? They were working a day ago but in the morning i jumped in to try them, no luck, dead.
Any help appreciated
Solo
« Last Edit: 11 June 2004, 06:10 by so1o »
Blue MK2
Re:speedo and heater went dead.
« Reply #1 on: 08 June 2004, 15:24 »
i think it could be your speedo cable thats come loose from behind the clocks as this happens to mine (very bumpy suspension) :(
Offline dubslug
« Reply #2 on: 08 June 2004, 16:46 »
or the cable has snapped??
has the resistor gone on the heater??
1992 pearl grey 8v
Offline so1o
« Reply #3 on: 09 June 2004, 07:41 »
Hmmmmm will have a good look at all these things, bad luck comes in three's. My starter motors packed up aswell. The bolt holding the two leads snapped :(
Offline so1o
Re:speedo and heater went dead lights wipers all dead.
« Reply #4 on: 11 June 2004, 06:12 »
Ok found a few more problems now. The wipers dont work nor do the headlights, dash lights up but headlights dont, beams work when stalk is pulled in. Is there a relay or something that could be blown that has stoppped all this from working. Seems as though most of the dash instruments dont work.
Chekd the cable behind the dash and its all connected up fine.
Any help?
« Last Edit: 11 June 2004, 06:13 by so1o »
Offline adyh
« Reply #5 on: 11 June 2004, 11:09 »
Hmmm .... ignition key barrell ?
it doesnt sound like the main feed on ign 1 & 2 is working to the fuse box , but the main engine feed is  .
Offline so1o
« Reply #6 on: 12 June 2004, 07:18 »
adyh....THIS MAN IS A GENIUS ;D. First thing i tried, spot on mate, new ignition barrel works perfectly.
Solo
Offline so1o
« Reply #7 on: 13 June 2004, 07:59 »
That sorted the problem out but the speedo still dont work, any ideas people, the back is all connected up, cable has not snapped. I did notice that the bit behind the dash where the cable goes into looked a bit worn?
Offline dubslug
« Reply #8 on: 13 June 2004, 14:56 »
disconnect it from the gear box and reconnect it again, worked for me
1992 pearl grey 8v
Offline so1o
« Reply #9 on: 15 June 2004, 06:01 »
Cheers, worked a treat, the orange spindle thingy was loose or something.
Solo
