Author Topic: Problems Removing Headunit  (Read 8958 times)
Offline hitmanip7
Re:Problems Removing Headunit
« Reply #10 on: 09 June 2004, 22:48 »
Thanks alot for that S11EPS, I will give it a try tommorow. :)
Offline S11EPS
  • No golfs here. Only a C63 mercedes
« Reply #11 on: 10 June 2004, 14:00 »
How did you get on mate?
The greatest leveller of them all - the Carousel
Offline hitmanip7
« Reply #12 on: 11 June 2004, 19:25 »
I think Ive found what you mean, but am having trouble getting something which fits and works.
This is a pic of my headunit http://www.iain.buildtolearn.com/images/hu.gif. Ive circled the two bits which I think are the bits you said about.
Do I need to insert something into both sides at once?
BTW: My headunit is a Sony XR-3759 :)
« Last Edit: 11 June 2004, 19:32 by hitmanip7 »
Offline S11EPS
« Reply #13 on: 14 June 2004, 08:25 »
yeah, they're the holes, they're in a slightly different position to cd units, but that doesn't matter.
When you buy one of those units, you do only get one key, as they can be done one at a time - basically you you push the key in one side, shift the unit diagonally so that side pops clear of its tags, then do the other side and the whole lot will slide clear.
If you pm me your address I'll post you a key, alternatively if you're anywhere near st. neots in cambridgeshire, swing by and i'll take it out for you (the stereo, that is).
Offline hitmanip7
« Reply #14 on: 14 June 2004, 16:54 »
Annoyingly I dont live anywhere near you :(
I bought some Sony Headunit keys today from Halfords. I tried what you said, but it didn't work. I also tried what the person in Halfords said, which was to insert the keys either side and lift it up slighty, but this didn't work.
I will try the garage I got the car from, they might know how to get it out.
These are the keys I got from halfords: http://www.secureonlineshopping.biz/caraudioplus/products.asp?recnumber=1038.
Ive just noticed it says "...where there are two horizontal slots along the bottom of the radio". Mine are at the top, so I think they might have been the wrong ones.
Offline hitmanip7
« Reply #15 on: 14 June 2004, 22:20 »
Well, I got it off in the end!  ;D
I ended up just taking out all the small screws on the HU its self, then I could see the two clips holding it in, which I just released. Then it slid out fine.
Thanks for all the help  :)
Offline percymon
Re: Problems Removing Headunit
« Reply #16 on: 27 March 2007, 12:03 »
Sony Head Unit Removal Help - 1997 Mk III
Help !! - I'm struggling to remove the old (ancient!) Sony XR 6559 radio cassette unit from my Mk III TDi - Pioneer DEH-P4900IB with ipod control going in its place  :grin:
Have made myself some flat approx 5-6mm wide removal tools , and inserted them into the slots top left hand corner and top right corner area but to no avail.  Tried the tools in at various distances, up to 4 inches in and still no sign of release.
The left hand side feels loose anyway, so its just the right hand one thats stopping the removal
I was about to resort to the crowbar, but i'll try the small screws as described above, unless anyone has a better suggestion.
Thanks
Offline percymon
« Reply #17 on: 27 March 2007, 15:14 »
Well thanks to hitmanip7's suggestion of removing the front facia plate i was able to see the retaining clips - there was no way any form of tool through the front slots was going to release these - in fact they look back to front to me, such that the only way to depress them by sliding a tool over the top would be from the rear of the unit !! :rolleyes: :rolleyes:
But some good news the wiring is untouched so the normal dual iso connectors on the cable loom, and a 2 into 1 connection cable from the isos to the sony unit.  Just got to pray the Pioneer is std dual isos, or the same single as the current sony  :undecided:
Offline Nickyb
« Reply #18 on: 27 March 2007, 22:46 »
Yeah all pioneer stuff is standard 2 plug ISO.
Just swap the Red and Yellow wires over on the new Pioneer loom which will just unplug, so instead of Red to Red, Yellow to Yellow, do Red to Yellow, Yellow to Red.
Otherside you will loose the memory on your new radio everytime you turn the ignition off.
If you have a roof arial you may also need an arial booster of the reception is poor.
Hope thats helpfull. :smiley:
Offline percymon
« Reply #19 on: 28 March 2007, 15:29 »
Cheers Nickyb,
new unit arived by courier at lunchtime, swapped the red and yellows over on the pioneer cable loom (simple bullet connections  :smiley::grin: :grin:  and plugged it all in - 10 minutes tops inlcuding replacing the frame in the dashboard.
Very impressed with the DEH-P4900IB so far - better go read the manuals now  :laugh: :laugh:
Will post some pics up later of before and after
Unit cost £110 from Bassjunkies, even came supplied with the optional CD-I200 ipod lead which i'll route through to the glovebox at the weekend (just stashed it under the headunit for the time being) - so full ipod charging and control from the headunit  :smug:
