Author Topic: Wats goin on here??  (Read 833 times)
Offline Benrevs
Wats goin on here??
« on: 01 December 2008, 23:35 »
  Right I have been sorting out all the wiring for the conversion and im a bit stumped.  I have taken a look over the fusebox guide and the diagram.  Problem is my fusebox is different than the diagram.  Most of it is the same, its just connector Y that doesnt match up.  Question is... is location Y supposed to be one connector, or 4 single ones??  I have 2 red single connectors, one of them goes to the battery and one bridges over to Z1.
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
Re: Wats goin on here??
« Reply #1 on: 01 December 2008, 23:52 »
Y
1 - red - electric seat switches
2 - red - electric window relay pin 30
3 - red - battery positive
4 - red - 16V CIS-E Motronic control unit Pin 19
Z1- red - injectors (Digifant models from fuel pump relay)
Y is 4 seperate single pin plugs.. really large spades.. horizontal, kinda, to all the others..?
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline Benrevs
« Reply #2 on: 02 December 2008, 00:12 »
I hear ya..  but pin number 4 on Y bridges to Z1.  Is that pin used on digifant for the fuel relay then??
« Reply #3 on: 02 December 2008, 11:29 »
if yours is actually a GTI thats wrong, Z1 is the output from the fuel pump relay and Y is 12v from the battery.  If you have a GTI and its wired liek that you've made a nice short circuit there ;)
I suspect you're getting confused, 30 should be bridged to 30b :)
Offline Benrevs
« Reply #4 on: 02 December 2008, 15:05 »
I was half wrong....   The 2nd pin from the end on connector Y bridges to 30b. But that still doesnt match up!! Bearing in mind I havnt touched any of this myself but there are markings on the fuse box so has been fiddled with previously. Also whilst im here.. I have just ripped out the girthy power cable from a beemer to run into my boot, is it a clear- run down the chassis rail to the back? thinking of hiding it through there as its like 20mm thick!
« Last Edit: 02 December 2008, 15:09 by afghan socks »
« Reply #5 on: 02 December 2008, 15:37 »
30 is a permanent 12v feed as well as Y so that'll be exactly the same as bridging 30 to 30b, so thats cool.
dont think its a clear run front to back along the chassis rail I'm afraid!
Offline Benrevs
« Reply #6 on: 02 December 2008, 16:25 »
Cool I was hoping that was the case! And was wishfull thinking on the rails...  lumpy carpet for me then as I dont fancy it uder the car!  Cheers dude.
