Author Topic: plastic behind door cards?  (Read 3139 times)
Offline Deefadog
  • Mk2 16V (November 89)
« on: 07 June 2004, 10:19 »
Can you buy these? or is it just as easy to get some polothen and cut it out your self, alos what is the best to stick it with?
Thanks
Offline benjam_in
Re:plastic behind door cards?
« Reply #1 on: 07 June 2004, 11:02 »
stick some polyethene sheet on with some duck tape or something?!? thats what i would do anyway!
Golf Mk2 Gti 1988
Offline Dizzie
  • Make friends with your fast
« Reply #2 on: 07 June 2004, 11:04 »
A bin bag and masking tape for me ;D
Offline Gambit
« Reply #3 on: 07 June 2004, 11:25 »
polythene sand bags from B&Q for me
Offline dan
« Reply #4 on: 07 June 2004, 12:13 »
I did the same as you gambit, B&Q sell large builders plastic sheets which worked a treat with Carpet tape (being nice and strong double sided).
Offline Deefadog
« Reply #5 on: 07 June 2004, 12:37 »
Cheers guyz, B&Q it is :)
Blue MK2
« Reply #6 on: 07 June 2004, 14:35 »
you will find that the duck tape wont last that long so i used some sort of  8)Blue-tak used by builders. It comes in a roll and is easy to shape, very sticky and water proof. Anyone know the name? Very handy sh!t ;)
 8)blue 8)
Offline Deefadog
« Reply #7 on: 07 June 2004, 22:50 »
Would no nails do the trick or some silicon from a tune? both are water tight!
« Reply #8 on: 08 June 2004, 11:29 »
I used porper duck tape & thick plastic sheeting from Focus.  I also cut an extra strip and stuck it along the lower half of the door and tucked it inside the bottom, as on the front doors water runs down the inside of the plastic and out the bottom drain holes.
VeeDubGTI16v
« Reply #9 on: 08 June 2004, 13:21 »
whats wrong with all your original ones???
i just re-stuck the original one with duck tape
