Author Topic: Bora sport , Anniversary clocks and pin out for the cluster loom.  (Read 26029 times)
Offline richw911
Popular upgrade for the mk4 is the bora sports clocks.
You can use this table to make sure you get the right one:
IE: Vw part no 1J5 920 925A
1J0 = standard clocks / 1J5 - Bora sport
920 = can bus
9 = mph / 8 = km/h
2 = half mfa / 4 = fis
5 = imob II 6 = imob III
C = diesel  A=petrol
There are two versions on the MK4 paltform these being Immo 2 and Immo 3, earlier models came as Immobiliser 2 and in early 2001 VW introduced Immobiliser 3 with the vehicle immobiliser being integrated into the cluster.
Sport clocks come in both immo2 and immo 3 the same as standard clocks.
You can tell which version you have by the part number of your cluster by the last numerical digit, 5 being immo 2 and 6 being immo 3.
EG: 1J0 920 926 C - immo 3 cluster / 1J0 920 925 C - immo 2 cluster
 You can put an immo 3 cluster into an immo 2 car (upgrade) but not an immo 2 cluster into an immo 3 car (downgrade)
* Anything but 6 on the end number is immo2 *
You can pick them up for around £70 - £80.  Petrol ones are quite rare TBH
Fitting.
You will need a SKC - Secret Key Code
The dealers cant help you as they no longer have access to it.
 If you have an earlier golf that came with the plastic tag on the spare keys the SKC may be printed on there.
The SKC can be retrieved with pieces of software such as Vag tacho.
PDF guide to clock coding : http://www.gwdale.co.uk/other/immo2_to_immo3_install.pdf
http://wiki.ross-tech.com/index.php/Immobilizer_III_Immobilizer_Swapping_%28Instrument_Cluster%29
To remove clocks:
http://forums.vwvortex.com/zerothread?id=1921113
Pics and full info here:
http://uk-mkivs.net/forums/p/167146/1096416.aspx#1096416
Here is the pin out for the cluster loom - big thanks to the clock guru Neil old_no7  :afro:
MK4 Cluster Harness GREEN
1 - Open
2 - Reader coil for immobilizer 1
3 - Indicator lamp for parking light*
4 - CAN Data Bus, shielded input
5 - W-wire*
6 - Indicator lamp for low windshield washer fluid - Power to silence alarm
7 - Brake pad wear indicator - Earth to silence alarm
8 - 9 - Open
10 - Low fuel level warning
11 - Signal for vehicle stationary*
12 - A/C clutch cut-off - Engine Coolant Temperature (ECT) signal
13 - Warning lamp for dual circuit brake system and handbrake
14 - ASR/ESP Indicator lamp (traction control)*
15 - 16 - Open
17 - Reading coil for immobilizer 2
* Where applicable
18 - Oil level thermal sensor*
19 - Interface - CAN Data Hi-Bus
20 - Interface - CAN Data Lo-Bus
21 - Open
22 - Hood alarm switch*
23 - Multi Function Trip Computer (MFI) - top row (forwards)
24 - MFI - bottom row (backwards)
25 - MFI - memory switch: reset
26 - MFI - ambient temperature display
27 - On Board Diagnostic (OBD) Interface - CAN Data Hi-Bus
27 - On Board Diagnostic (OBD) Interface - CAN Data Lo-Bus
29 - 32 - Open
___________________________________________________________
MK4 Cluster harness BLUE
1 - Terminal 15 - positive (ignition on)
2 - Indicator lamp for turn signal, right
3 - Output signal 1 from electronic speedometer
4 - Open
5 - Fuel gauge
6 - Airbag Malfunction Indicator Lamp (MIL)
7 - Terminal 31 - sensor/sender Ground (GND)
8 - Engine Coolant Temperature (ECT) gauge
9 - Terminal 31 - Ground (GND)
10 - Oil pressure warning lamp................................................
11 - Open
12 - Terminal 61 - warning lamp for Generator (GEN),
13 - 15 - Open
16 - Warning lamp for rear hatch/trunk lid open
17 - Terminal 56a - indicator lamp for high beam headlight
18 - Indicator lamp for turn signal, left
19 - Warning lamp for Anti-lock Brake System (ABS)
20 - Terminal 58b - instrument cluster illumination
21 - Driver's door open warning buzzer 1
22 - Warning lamp for low Engine Coolant Level (ECL)
23 - Terminal 30 - positive (B+)
24 - Terminal 31 - Ground (GND)
25 - Data Link Connector (DLC) K-wire
26 - Parking lights, right (signal for "lights on" warning buzzer)
27 - Parking lights, left, (signal for "lights on" warning buzzer)
28 - Input signal - Speedometer Vehicle Speed Sensor (VSS)
29 - Brake fluid level warning lamp
30 - Terminal 86s - Ignition key warning buzzer
31 - Seat belt warning lamp/buzzer
32 - Open
« Last Edit: 29 December 2013, 19:46 by richw911 »
Offline tokemk4gti.t
  • 2001 gti turbo :-)
do you have to remove the battery before removing the plugs on the cluster??
