Author Topic: Roaming revs at idle  (Read 1334 times)
Offline grmair
« on: 29 November 2008, 20:58 »
My Mk 5 GTI has started revving very randomly.  At idle the revs sit at about 1200 then rise to 2000 or 3000 over a few seconds, then returns to about 1200.  I can't be sure but it feels like it's lost some power too.  Any suggestions where to start looking would be appreciated.
Offline Komenda
Re: Roaming revs at idle
« Reply #1 on: 29 November 2008, 21:06 »
One or more of the coil packs could be on their way out.
Offline grmair
« Reply #2 on: 30 November 2008, 18:48 »
Thanks Komenda,
It's a long story but i have had problems with them before. I had over-spec'd plugs in and they were burning out the coils.  It's possible that one was damaged at the time i sorted the plugs out and is only now showing the signs after degrading over time.  Is there a simple way to test the coils for damage? As far as i know they're packaged pretty tight. This one's a real annoyance!
Offline bacillus
« Reply #3 on: 30 November 2008, 19:01 »
Thanks Komenda,
What type of plugs??
Without traction power is nothing!
Offline grmair
« Reply #4 on: 30 November 2008, 19:37 »
I put Denso Iridium's in.  They claimed to be suitable but they burned at too high temperature and blah blah blah.  I replaced it with proper standard Bosch Platinums and all was fixed.  All i can think of is if you're right, one of the coils was still damaged but has got worse over time.  Maybe it's that or maybe it's a completely new problem.  I'm scratching my head at the minute...
Offline bacillus
« Reply #5 on: 30 November 2008, 21:05 »
hmm, are you saying that your car idles at 1200rpm when warm?
Offline Riz
« Reply #6 on: 10 April 2009, 22:17 »
what was the Fix? i think i have coils
Offline DanoGTI
« Reply #7 on: 11 April 2009, 08:16 »
Just to add to the mix - fwiw, I had the same type of issue with my Scooby.
The MAF (Mass Air Flow) sensor was dirty/failing. Caused the performance to drop off (BIG time) and also the idling was erratic.
Personally, I'd still go the coilpacks, but it might be worth checking the MAF out too :)
HTH & "good luck"
Dan :)
DA Productions
The fine art of diplomacy is telling somebody to "fcuk off" in such a way that they actually look forward to the journey....
