Author Topic: Stupid question about torque-arm insert  (Read 1959 times)
Peskarik
« on: 29 November 2008, 08:57 »
Do I need one or two of them?
Offline gazbutmk5gti
Re: Stupid question about torque-arm insert
« Reply #1 on: 29 November 2008, 09:11 »
Revo stg2+ & lots more
Offline zippytwo
« Reply #2 on: 29 November 2008, 09:22 »
Even more stupid question - what is a torque-arm insert and what does it do?!
Peskarik
« Reply #3 on: 29 November 2008, 11:14 »
"Under hard acceleration, your entire engine and transmission actually rotates due to compliance in the factory bushings. While the soft factory bushings do a good job of damping engine vibration, they can also create a rubbery, vague response in the vehicle's powertrain.
With the insert installed, you car's throttle response will feel better and your shifts will feel more crisp and defined.
Please note that polyurethane is not as compliant as rubber. As a result, you may notice a slight increase in ride harshess and engine vibration after installation."
Peskarik
