Author Topic: stub axle bolts need advice urgently  (Read 882 times)
Offline richard s
« on: 28 November 2008, 16:33 »
i am in the middle of changing my rear discs/pads/wheel bearings/back plates and to change the backplates i needed to take the stub axles off 7 bolts came off without too much trouble but the last one had to be removed with my irwins hence is now chewed up so what i need to know is what type of bolts do i need
i put some on from b&q (m10x25mm zinc plated avf) but left it there as not sure if they are ok
old bolts had a head size of 14mm and the b&q ones are 17mm  also with it holding the wheel and brakes onto the car i dont really want to be running the risc of losing a wheel at 60 mph
i would go to vw but i need car to be ready monday as starting new job and they will not have any stock (they never have anything in stock that i want)
all help is greatfully recieved as i only have till saturday lunch to source correct bolts
Offline Mew
Re: stub axle bolts need advice urgently
« Reply #1 on: 28 November 2008, 16:39 »
Phone them up now and ask if they're in stock :wink:
Offline richard s
« Reply #2 on: 28 November 2008, 16:46 »
theyre not answering their phone will try in morning but i know what answer will be
Offline Diamond Hell
  • Opinions я Us
« Reply #3 on: 28 November 2008, 16:56 »
£10 quid says the originals were 10.9 - stronger than your boggo B&Q bolts.  Try a specialist supplier.
Offline sidecarphil
« Reply #4 on: 28 November 2008, 17:08 »
i ordered some thing today and it will be in tommorrow :)
guess we got a good VW dealer ere
Offline richard s
« Reply #5 on: 28 November 2008, 17:11 »
found one called williams fasteners will be calling down tomorrow
cheers diamond do i ask for 10.9 bolts or do they go by another name
Offline richard s
« Reply #6 on: 28 November 2008, 17:16 »
my local dealer can get stuff next day usually but not a chance late on a friday afternoon when they dont want to answer phone
and ive had it before when the wrong part comes and that means 3 days without being able to work on car
