Author Topic: Why is my clutch squeaking?  (Read 1037 times)
Offline TheRaven
  • "I am female, I think the boobs are a giveaway..."
« on: 27 November 2008, 22:14 »
Basically every time i push the pedal down then bring it back up it squeaks + creaks.
Any ideas why?
Much appreciated!
Professional Freelance Equestrian Photographer
www.ravenphotography.co.uk
www.ravenphotography.uk
Offline Horney
Re: Why is my clutch squeaking?
« Reply #1 on: 27 November 2008, 22:16 »
Needs some oil on it. Something like 3 in 1 oil but be very careful to use a very small amount and watch what you do with it. Last thing you want is oil on your pedal rubbers. Anyone who's got Diesel on the bottom of their shoe after going to the petrol station will tell you how frightening that is!
Nick
Offline TheRaven
« Reply #2 on: 27 November 2008, 22:22 »
Brill, thought it mite have bin worse! So should I just put it on the joint of the clutch pedal?
Offline cняis
« Reply #3 on: 27 November 2008, 22:24 »
i would be wondering whether this is a clutch or clutch pedal problem  :huh:
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #4 on: 28 November 2008, 08:40 »
Isn't the clutch pedal hinge a plastic bush? If so, then lubricate it with silicon spray. (Interior dashboard cleaner!) WD40, 3 in 1 or any other oil will knacker the bush.
Offline andy mk2GTI
« Reply #5 on: 28 November 2008, 08:45 »
vegeable oil can also be used on rubber bushes if you dont have silicon :smiley:
Offline Agreeable Slick
  • Unit
« Reply #6 on: 28 November 2008, 19:51 »
no it can't it still degrades rubber.
Offline my white golf
« Reply #7 on: 28 November 2008, 20:25 »
if it is from the interior than a good old fashioned bit of oil should fix it, but if it is from the gearbox side it could be comething like the release bearing , if so you should get it checked out.
old school rules
  • Unit
« Reply #8 on: 29 November 2008, 13:55 »
release bearings tend to rattle rather than squeak.
