Author Topic: 2 More questions on my Mk2 16v  (Read 2198 times)
Offline Redcap
« on: 05 June 2004, 23:18 »
1. Can anyone confirm torque settings on exhaust cam sprocket? Book says 180 nm, is this correct?
2. Oil leak inside distributor! I can find an external oil seal (Large green rubber washer thing) Is there an internal seal in the distributor body? I cant work this one out. Diagram doesnt show a seal, and there is no seal on the cam! Why is that?
Any instructions would be greatly appreciated.
Ta
Its a GTi
Offline mk1
Re:2 More questions on my Mk2 16v
« Reply #1 on: 06 June 2004, 18:46 »
Cam sprocket is 80 nm. There is a oil seal inside the distributor and you will have to strip it to replace the seal, no seal on the cam so the dist drive gets lubricated.
Steve.
VeeDubGTI16v
« Reply #2 on: 06 June 2004, 19:00 »
where can you get the seals from?
Offline Gambit
« Reply #3 on: 07 June 2004, 11:22 »
Bosch specialist will have the seals, you need a 12.5mm one, or is the dizzy is pretty old and worn you'l get away with a 12mm seal
VW dont stock them
VeeDubGTI16v
« Reply #4 on: 07 June 2004, 11:26 »
they are just standard o-ring seals tho?
Offline mk1
« Reply #5 on: 07 June 2004, 18:55 »
Get the "o" ring from VW, it is not expensive. The seal inside the distributor is 12.5x19x5 and not available from VW, if you go to a seal supplier you probably wont be able to get that size as the 12.5 is a half size. Get a 12x19x5 and as the 12 is a little tighter it makes up for the wear on the shaft ;).
Steve.
