Author Topic: mot failure :(  (Read 2935 times)
Offline g-mac-gti
  • GTI 8V
mot failure :(
« on: 26 November 2008, 21:44 »
my car failed its mot today  :sad: reg bulb, welding :cry: and my :cry: nearside rear brake load sensing vavle linkage has seized! what the hell is that??? and how can i unseize it????
BAD ASS GIRLS DRIVE BAD ASS TOYS
Offline Steve_B
Re: mot failure :(
« Reply #1 on: 26 November 2008, 22:31 »
Do they mean the rear bias valve? If so there should be a few posts about it on here.
Offline cняis
Re: mot failure :(
« Reply #2 on: 26 November 2008, 22:34 »
mine passed today... with a page full of advisories  :rolleyes:
there are advantages to working for a car spares company with workshop and MOT testing station  :grin:
i had to keep mr MOT tester topped up with coffee!
Offline oakgreen_91
Re: mot failure :(
« Reply #3 on: 26 November 2008, 22:36 »
The bias valve is easy to spot, it sits near the rear axle on the n/s - follow the brake pipes into it!
You can the usual WD40 it to death approach, or buy a new one for about £30
Looks like this (when new):
2012 Audi A4 Avant Black Edition TDI 177
2012 Megane RenaultSport 250 Cup
1991 Volkswagen Golf GTI 8v
1990 Renault 5 GT Turbo
Offline g-mac-gti
  • GTI 8V
Re: mot failure :(
« Reply #4 on: 26 November 2008, 22:40 »
rub it in why dont you :tongue: haha
Offline g-mac-gti
  • GTI 8V
Re: mot failure :(
« Reply #5 on: 26 November 2008, 22:41 »
cheers guys. well you know how it is, christmas comin up. ill try the cheap option...wd40 here i come
Offline AudiA8Quattro
Re: mot failure :(
« Reply #6 on: 27 November 2008, 09:00 »
Use wd40 and a rubber mallet on the bias valve.
Offline Diamond Hell
  • Opinions я Us
Re: mot failure :(
« Reply #7 on: 27 November 2008, 09:40 »
DON'T use WD-f*cking-40 on it!
Use something that *actually* has an effect - Plusgas, or another penetrating fluid.  You will have much better results.
When you get the brake unions cracked off you may want to rock them back and forth to make sure the union is separated from the pipe - nothing worse than twisting off the end of one of your brake pipes, is there?
Re: mot failure :(
« Reply #8 on: 27 November 2008, 09:42 »
Nothing wrong with using WD40 at all.
The valve probably won't even need replacing, i've sorted several before by just using wd40 and a rubber mallet to free it up.
Offline jacko16v
Re: mot failure :(
« Reply #9 on: 27 November 2008, 15:57 »
Yeah it will free up with some lube and a good clean to get all the crap and rust out of the linkage
