Author Topic: got myself an abf :-)  (Read 4572 times)
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
Re: got myself an abf :-)
« Reply #20 on: 25 November 2008, 05:42 »
I'm glad thats all cleared up then. My toledo has 4 studs, jays fault he confused me  :laugh:. You say very very hard to do. Can you go into a bit more detail of what i'm getting my self into pleassseee. I see its a cable change box for starters. Ive got ample time to get it done, although 3-4 months would be good.
« Last Edit: 25 November 2008, 05:47 by oakgreengolf »
« Reply #21 on: 25 November 2008, 09:52 »
280 calipers are thicker than 256, as the 280 disc is thicker. 256 ones will fit 280 carriers but with some pad/disc combos the 256 caliper wont fit over the 280 disc.  You can grind down the slider pins a touch, or use part-worn pads to get around this.
Offline Jay
  • balding fat cvnt
« Reply #22 on: 25 November 2008, 15:15 »
DH, want to explain why you're changing your mind about ABF's?
Offline Mew
« Reply #23 on: 25 November 2008, 15:22 »
I'm guessing because a fair few people are buying them to put into their golfs, meaning there are less around for him to have a play with. That's how i read it anyway!
Offline Diamond Hell
  • Opinions я Us
« Reply #24 on: 25 November 2008, 17:17 »
The guy's a mind-reader.
Now leave the engines alone - Danny needs spares and I will in due course!
Offline Jay
  • balding fat cvnt
« Reply #25 on: 25 November 2008, 17:35 »
and there I was thinking that he would have a technical reason, not a selfish reason  :tongue:
sharpie
« Reply #26 on: 25 November 2008, 17:40 »
funny i was just saying this
« Reply #27 on: 25 November 2008, 21:06 »
ok i'm going to start looking for bits for the conversion. Ive got a 4-1 manifold at the mo with a miltec exhaust. I take it i will have clearence issues with this. Having read some previous threads the g60 down pipe is my best as it has the lamba in it.
  • Opinions я Us
« Reply #28 on: 25 November 2008, 21:09 »
Don't over-intellectualise the metal bits of the conversion - the biggest challenge is the wiring.
Your current exhaust can have a lambda boss welded in - cut out an appropriate boss from another system and weld it into your exhaust, maybe on a cross piece between your secondaries.
Or you can pay some monkey firm to do it for you, if you lack basic mechanic skills, like the ability to weld.
« Reply #29 on: 25 November 2008, 21:20 »
welding is not a problem. just read somewhere on here about clearence issues.
