Author Topic: motorway problem!!! ---- FIXED!!!!!!!!  (Read 7011 times)
Re: motorway problem!!!
« Reply #20 on: 25 November 2008, 09:39 »
ok that piece may be webber only then? try these guys:
http://www.webcon.co.uk
Offline Khare
  • The bear that khares
« Reply #21 on: 30 November 2008, 17:31 »
right. Still havent found a carb mounting flange, but i had a good look toda, and i cant really tell if its cracked, or its just the way it was moulded (injecton moulded style, were you can see the line where the two moulds join)
I did mention to diamond hell a while ago my fuel pump is leaking, he said replace it, which i havent done so yet, but i will make a trip to GSF either tomorrow or tuesday and change it. Do you think that fuel pump could be the culprit?
Today i had to drive 300 miles and about 200 of them was with the problem, was a right pain. When i pull the choke up, it helps, but problem still there, just not as bad. So it means that when there's less air coming in, it seems to go better, which leads me to believe its maybe the pump, when theres alot of air the pump cant get enough petrol to the carb so it missfires/jumps. thats my theory anyway. will replace the pump this week and see how it goes. This problem is reaaaaaly getting on my t!ts now, before where i used to jump in the car and enjoy the drive, now its a game of tension and hopeing it wotn cut out at the next junction or while on the move :sad:
« Reply #22 on: 30 November 2008, 17:47 »
aye possibly! is the fuel reservoir still there or was that removed when the webbr was fitted?
Offline Khare
« Reply #23 on: 30 November 2008, 17:54 »
fuel reservoir still there. Pump is leaking quite abit now, wel tmorrow i'l buy a new pump, and fit it. i need this problem fixed asap, as i need to do alot of miles this week and weekend so will need the car in tip top condition.
Offline JC
  • Back in the North.
« Reply #24 on: 30 November 2008, 18:12 »
oh you reckon, the old MkIIs a tempremental thing, it will know you have just bought a MK3 BarGti it will give you nothing but hassle from now til January  :grin:
Offline Khare
« Reply #25 on: 30 November 2008, 20:46 »
haha thats my worst fear. it was actually a coincidence, cos the problem started around the time where i decided to look for another car, so yeah , i do think my mk2 is doing it on purpose. :grin:
Offline Dolly
« Reply #26 on: 30 November 2008, 23:05 »
turn up the boost! i mean the mixture screw
Offline danny_p
« Reply #27 on: 01 December 2008, 01:00 »
change the fuel resovor and clean the jets and bottom of the float chamber
all the VW's have gone bar 1.
Offline Khare
« Reply #28 on: 01 December 2008, 10:02 »
how would changing the fuel reservoir help?
Ive arranged to go up to diamond hell's workshop sometime in the next few weeks and get it running sweet. hopefully gonna replace fuel pump today and that should sort out the problem.
Offline danny_p
« Reply #29 on: 01 December 2008, 15:38 »
fuel resovor (pressure reg) can corrode and collect sh!t on the inside,  there are 2 ways it can piss the carb off,
a)  if it's knackerd it dosen't supply adiquate pressure to the carb
b)  they can corrode on the inside and collect crap as well then pass this into the carb  whitch causes merrry hell.    it is highly optimal to fit a new resovor and a filter between the carb and resovor / pressure reg.   my old syncro used to suffer with this problem till changed it
