Author Topic: corrado top mounts the same as mk2 golf?  (Read 1395 times)
Offline adam_mk2
« on: 22 November 2008, 22:30 »
as title, i removed some suspension from a corrado 1990 1.8 16v and just wondered if i could just put it straight on my mk2 without the hassle of changing the top mounts over?
Offline Diamond Hell
  • Opinions я Us
Re: corrado top mounts the same as mk2 golf?
« Reply #1 on: 22 November 2008, 22:38 »
ETKA says no.
They're G3 top mounts.
Will fit.
Might lift the front a little.
Offline Khare
  • The bear that khares
Offline adam_mk2
« Reply #3 on: 23 November 2008, 08:01 »
well ill give it  go then, they got 60mm springs on them anyway, got coilovers but not fitting them till after winter, dont want the threads to get all sh!tty
Offline ToddyGTi
  • I Love GTi's
« Reply #4 on: 23 November 2008, 08:15 »
They are the same I believe as the rado is basically G2 at the front and passat at the rear iirc
Part of the Booty Club
« Reply #5 on: 23 November 2008, 12:15 »
It will all go straight on. The only Corrados that got golf 3 mounts was the VR6, and very late post 95 models.  Even if it had MK3 mounts it would still fit if you put the whole lot on together, the MK3 top mounts are supposedly a good upgrade for strength.
The non-MK3 setup Corrado stuff is identical to MK2 golf suspention, using same top mounts as MK2 G60 just slightly different spring poundage (though the rado springs are listed for a random jetta model).
