Author Topic: golf mk5 number plate bulbs  (Read 3739 times)
r4vvm
« on: 21 November 2008, 18:53 »
is it possible to u[grade the rear number plate bulbs, if so how easy is it to do?
i want to buy sum LED type bulbs or the white lights ones anyone know where to get them?
WhiteGTI
Re: golf mk5 number plate bulbs
« Reply #1 on: 21 November 2008, 19:07 »
LED's wont work I'm afraid.. unless you solder in a resistor.
They don't draw enough power, which then fools the car into thinking that the bulb has gone, and therefore it stops all current going to that bulb.
 :smiley:
Offline JPC
« Reply #2 on: 21 November 2008, 19:27 »
polarg festoon bulbs are what you need pal
WhiteGTI
« Reply #3 on: 21 November 2008, 19:57 »
You have a link to somewhere that sells those JPC??
Do they put out a similar colour light to an LED then?
Cheers pal.
Offline Cooper7
« Reply #4 on: 22 November 2008, 01:04 »
Could go for the PIAA ones with the integrated resistor but they arent cheap:
http://www.shopatron.com/product/product_id=PIA19325/353.0
MKV Steel Grey GTI
WhiteGTI
« Reply #5 on: 22 November 2008, 07:26 »
That is interesting! But as you say...not cheap at all!!!!
Bet that only cost them pennies to make!
Offline JPC
« Reply #6 on: 22 November 2008, 09:30 »
there are ecs numberplate bulbs you can get which have LEDs plus an intergrated resistor, but there not cheap. they give out aa slightly blue light, which does look a bit tacky, as far as im aware!
the polarg ones are bulbs with blue coating (similar to philips white sidelight bulbs) but they are filament bulbs so they dont throw up any "bulb out" errors
Offline TagnuT
  • Edition 30
« Reply #7 on: 24 November 2008, 20:25 »
Stay away from the Polarg bulbs, there have been quite a few posts where the reg plate bulb holders have melted:-
"I'm actually in a similar situation, I purchased a set of the "Polarg B1 Hybrid" bulbs approx 6-8 months ago for my license plate (also tinted blue bulbs), I had them on for no problem. A couple days ago, when I wanted to switch from the blue bulbs to led(with resistors), I found out that the upper part of the housing (contact point to the hatch) was melted. Worried there might be a problem, I switched back to stock bulbs, but then both sides don't turn on and computer gives me a warning. "
There was a long thread on VWVortex about it, can't find it at the moment.
« Last Edit: 24 November 2008, 21:34 by TagnuT »
Bye Bye Edition 30
WhiteGTI
« Reply #8 on: 24 November 2008, 21:02 »
Oh!!
Thanks for the advice TagnuT  :smiley: :smiley:
Offline TagnuT
  • Edition 30
« Reply #9 on: 24 November 2008, 21:35 »
No Prob  :wink:
Bye Bye Edition 30
