Author Topic: Alternator problem, help needed!  (Read 1291 times)
Offline t111bul
« on: 21 November 2008, 17:04 »
Hi guys
I have a 90 spec 16v that the battery keeps going flat on. I have a battery/alternator tester that keeps saying the car is charging ok until i turn on the electrics. I have tired three alternators and they all give the same results, they arn't new but the 3rd one came of tried and tested car. Does any one know what might be wrong?
Tim
Offline JC
  • Back in the North.
Re: Alternator problem, help needed!
« Reply #1 on: 21 November 2008, 17:08 »
how much is the battery reading ( volts )  across the terminals at the follwoing times
1, engine off
2, engine running without much load
3, engine running with load ( lights, heater, rear window etc )
Offline Organisys
  • Old and Slow...
« Reply #2 on: 21 November 2008, 17:19 »
...and check all your earth connections carefully.
Offline t111bul
« Reply #3 on: 22 November 2008, 13:05 »
Hi,
My battery charger says the battery is 12.6 volts but i haven't checked the voltage when running and then with electrics on as my tester just comes up with lights to tell you the state of charge and alternator state. I'll try and find my volt meter to test the voltage and i'll clean all my earth points up and see if that helps.
Offline JC
« Reply #4 on: 22 November 2008, 13:41 »
yep, need to see wot volts its kicking out when the engine running before we can move on  :wink:
Offline t111bul
« Reply #5 on: 23 November 2008, 11:44 »
I've just been out in the cold checking my battery, The battery without the car running is 12.2 volts, with the car running it's 13.8 volts and with all the electrical stuff turned on it's 11.8 volts at idle and with 2000ish rev's its 13.2 volts. I would of thought this sounds about right?
Offline JC
« Reply #6 on: 23 November 2008, 11:47 »
yep, sounds about right,
so its charging ok,
so either the battery is goosed ( how come i wasnt flat when you went out to it today ???? )
or you got summat draining it, alarm, boot interior light or summat ???????
Offline danny_p
« Reply #7 on: 23 November 2008, 11:49 »
battery hate the cold  if they are weack  a cold morning will knock them out till it warms up, when this happens theres only a few week left in them anyway tho
all the VW's have gone bar 1.
Offline t111bul
« Reply #8 on: 23 November 2008, 12:17 »
I work away so the car does get left for a couple of weeks at a time, i charged the battery up two weeks ago and left it disconnected so it hasn't gone flat. The car only has an led for the imobiliser so it must be that thats making it go flat! At least the car is ok to use now.
Offline t111bul
« Reply #9 on: 23 November 2008, 12:19 »
Oh and the battery is the second new one in 3 months so it should be ok and the car is kept in a garage so it doesn't get that cold.
