Author Topic: leaking air con pipe  (Read 2376 times)
Offline speazzzzz
« on: 04 June 2004, 03:51 »
dealer says there is a hole in my air con pipe, will cost ?137 for the pipe plus the labour, can you guys shed any light on this ? the effect of it ? and a realistic price ?
Offline shagmeister
Re:leaking air con pipe
« Reply #1 on: 11 June 2004, 17:04 »
what were the symptoms when this all came on
? think mine might be going down the same line, ta shagmeister
Offline speazzzzz
« Reply #2 on: 18 June 2004, 05:29 »
i have no idea, i think there is just a lack of thrust when u use the air con....but havent noticed yet
Offline papperbear
  • Ding Dang Doo ...!
« Reply #3 on: 18 June 2004, 12:58 »
I would suggest that a local VW specialist or a air con engineer would be able to fix this cheaper than the stealer!
My climatronic system blows semi cold air out when on the lowest setting so I need to get my system re-gassed, VW wanted ?105 and a local re-fridgeration engineer would do it for about ?45.
The difference between the 2 is that VW will empty all the gas and dispose of it, where as the other guys will just top up the system.
HTH
Offline Sooty and Sweep
  • I8ABS
« Reply #4 on: 24 June 2004, 08:24 »
I may be wrong but... doesn't the air-con gas show up in UV light(blacklight)?
If you hold a uv lamp in the engine bay the leaking gas should light up, revealing the leaky pipe...
ABS Sucks!!!
