Author Topic: MK2 Dizzy problem  (Read 1790 times)
Offline Uruk Hai
MK2 Dizzy problem
« on: 21 November 2008, 15:14 »
I have a 91 8V GTI and a while back it developed a problem where the car would run fine on short journeys but if I went on a longer run (over about 6 miles) it wouldnt start again until it had cooled right down. It turned out to be something in the dizzy (probably hall sender) but fortunately I had a spare dizzy and now the old girls fitted and time'd up she's running as sweet as a nut again. I just thought I would post this as I've never had a probelm like this before with any car and had it not been for a good mate of mine who's awesome on the spanners I may have spent a fortune trying to find what at first seemed like a intermitent problem !
Offline sidecarphil
Re: MK2 Dizzy problem
« Reply #1 on: 21 November 2008, 19:07 »
when you say it wouldn't start , in what way ??
mine will start when it is warm (hot it is ok) but then it rev's slightly then pops backfires and stop's eventually
i cannot keep it running with the throttle as it just stop's
i have changed the blue temp sensor , air flow meter , plug's lead's dissy cap and rotor arm
i have a new ecu due to an earth fault after changing the clutch
the filters were changed about 3k ago including a cam belt and fuel filter
the car is a 8v digi from 1989
this problem is pi55ing me off now as i have spent a fortune on the car and getting nowhere
Offline Khare
  • The bear that khares
« Reply #2 on: 21 November 2008, 19:28 »
sounds like timing could be out when the belts were replaced.
Offline sidecarphil
« Reply #3 on: 21 November 2008, 20:50 »
i have done over 3k since the belt's were changed , but there was a run around the nurburgring
HMMMMMMM i wonder  :undecided: :undecided: :undecided:
Offline Uruk Hai
« Reply #4 on: 22 November 2008, 11:33 »
When I say wouldnt start it was turning over and over without firing at all, then after a while it just started up almost the instant I touched the key.
Offline sidecarphil
« Reply #5 on: 22 November 2008, 15:12 »
now it is reving at 2k instead of idle   :angry: :angry:
i think this car hates me !!!!!
Offline DubJoey
« Reply #6 on: 23 November 2008, 09:00 »
Hi I have a 89 MK2 Gti and it has a misfire problem too but It can happen anytime hot or cold doesn't matter you can be driving along and it just seems to go dead the rev counter drops to zero instantly but if you turn ignition off and back on it fires up and just carries on normally. The car never misfires or anything else it runs fine appart from this every so often if anyone has any ideas please let me no its starting to really annoy me now. The cars had new ht leads dizzy cap and spark plugs and someone has said it could be a dizzy problem
Offline danny_p
« Reply #7 on: 23 November 2008, 11:51 »
thats chould be the ignition amp,  or hall pickup
all the VW's have gone bar 1.
Offline DubJoey
« Reply #8 on: 23 November 2008, 17:13 »
whats that and where is it
Offline sidecarphil
« Reply #9 on: 23 November 2008, 17:26 »
ign amp is on top to the ECU (left rear under the bonnet) on my LHD GTi digi
hall sensor is in the Dizzy
