Author Topic: 90 spec sills - attachment?  (Read 2811 times)
Offline G-Lader
« on: 03 June 2004, 13:25 »
Wonder if you could please advise, bought some 2nd hand 90 spec sills and arches to go with the 90 spec bumpers Ive had on for ages.
The sill mounting strips seem to attach to the car sills by way of double sided tape. Is this right?
Thanks
Mk 11 8v - Bright blue metallic, 5 door.
Passat 20vT wagon on 18's.
Offline MK4_20VT
Re:90 spec sills - attachment?
« Reply #1 on: 03 June 2004, 14:11 »
Hey, I posted the same question about a month ago & I got no reply.
After a bit of looking around I found the parts that you need
1.  2 sill strips, this is stuck to your sill.
2.  10 sill clips, that stick to the moulding & to the sill strips.
These parts can only be purchased from a VW dealership
Hope this helps (mine will be going on when I get a chance)
Offline Gambit
« Reply #2 on: 03 June 2004, 15:16 »
try GermanSwedishFrench or http://www.gpcvwaudi.com
and ask them for a 90 spec outer sill fitting kit
costs about ?18 + vat - that covers both sides
Offline lowgolf
« Reply #3 on: 03 June 2004, 18:15 »
Is this the same for g60?
<br /><br />Yeah!!!
« Reply #4 on: 04 June 2004, 08:19 »
I thought the G60 has the same sills as the std GTI?  Just the arches that are different?
Offline Gambit
« Reply #5 on: 04 June 2004, 10:47 »
yeah G60 sills are just the same
Offline wallpaper_01
« Reply #6 on: 04 June 2004, 13:33 »
i thought the G60 sills under the door were different???
Offline lowgolf
« Reply #7 on: 05 June 2004, 09:42 »
I thought they were wider, just have to see on sunday when thay arrive  ;D
<br /><br />Yeah!!!
