Author Topic: rubjonny must be able to help  (Read 2835 times)
Offline ian007miles
« on: 19 November 2008, 23:12 »
hi i have just took my alternator off and got it chromed and i took the wire out from under the bonnet and was going to re do it but now i have lost it so can any 1 tell me wot terminal goes to wot there are 3 spade terminals on the alternator 2 big and 1 small. thanx ian
« Last Edit: 24 November 2008, 20:17 by ian007miles »
Agu|k03s|forge 007 dv|forge boost pipes|forge water pipes|forge tip|forge kona cold air intake|milltex 3" down pipe sports cat|milltek cat back exhaust|r-tech custom remap 238bhp and 235 torque
Re: rubjonny must be able to help
« Reply #1 on: 25 November 2008, 09:56 »
looking at the bentley wiring diagrams, it would apear the blue wire goes to terminal D+, and the 2 wires left over go on the other 2 terminals, whichever way you like :)
Offline ian007miles
« Reply #2 on: 25 November 2008, 23:18 »
hi thanx mate does one go to the starter motor cos ive got to make a new alternator loom coz i misplaced(lost) the original one and i cant remember were the 2 bis conecors go i no the small 1 out of the 3 go to a wire that comes from behind the battery. i dont think that the one i took off was the original one any way coz the wires were well tightly pulled across the front of the engine i no 1 went to the battery but i dont remenber were the other 1 went and i dont no which 1 goes were. hope that makes sense thanx ian
« Reply #3 on: 26 November 2008, 08:23 »
apparently they both go to the starter  :undecided:
Offline ian007miles
« Reply #4 on: 27 November 2008, 16:29 »
i was told that one went to the starter and one went to the batery
« Reply #5 on: 27 November 2008, 17:16 »
doesnt really matter, battery & starter are both linked anyway!
Offline kraM
  • It's not the speed, it's the sudden stops...
« Reply #6 on: 02 December 2008, 13:29 »
Hi
Alternator
Blue wire to the little terminal on the alternator (as rubjonny says)
2X Red wires to the battery + terminal
Starter
Big thick wire to the big bolt terminal on the starter
Red and ??? wire to the spade connector on the starter
(NOW FOR THE OVER THE TOP BIT, SORRY:) )
IF IN DOUBT,  get some one who knows or another car the same spec as yours to copy.  IF YOU PHUQ IT UP, and run an un-fuesd link from the battery to an earth point, the very best you hope for is a big arse sparky moment, next level - a buggared alternator, next level - a poped battery, worst case big huge electrical fire, car a shell and battery explodes covering you with acid and damaging what ever gets in its way.
Sorry to be a misserable bastard, but it could happen, I've shorted out enough batteries in my time to keep M&S afloat in pant sales for life.
This happy reply was brought to you by
kraM
(who is on his second day off, waiting for bearing suppliers to supply bearings ARGHHHHHHHHHHH)
It's not the speed... it's the sudden stops...
Offline ian007miles
« Reply #7 on: 02 December 2008, 14:32 »
thanx for all your help ive sorted it now thanx again
