Author Topic: 2 beeps  (Read 1222 times)
Offline barry-gti
2 beeps
« on: 16 November 2008, 19:22 »
helloooo
today i was coming off the motorway and i was going round a roundabout (kinda quick, about 30) and 2 beeps came from my dash. anyone had this before??
thanks
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: 2 beeps
« Reply #1 on: 16 November 2008, 19:28 »
Probably find the oil light came on with this, check the oil ASAP!  if you turn a corner and the oil is low it will drop and the warning light will flash and beep.
check the oil!!!
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline MK3GTI_16Valve
Re: 2 beeps
« Reply #2 on: 16 November 2008, 23:30 »
defo oil, sort it asap
Offline barry-gti
Re: 2 beeps
« Reply #3 on: 17 November 2008, 08:51 »
kk will deffo do that, i only topped it the other day aswell, everytime i first start it in the mornings a load of smoke comes out aswell, could that be oil??
Offline troublestarter
Re: 2 beeps
« Reply #4 on: 17 November 2008, 09:42 »
the beeping as far as i recall does not indicate low oil level but low oil PRESSURE
www.awesomeautomotive.co.uk<br />mobile vehicle security & audio fitting service<br />insurance accredited
Offline dekadent31
Re: 2 beeps
« Reply #5 on: 17 November 2008, 11:23 »
check your oil, it must be something with the oil
Offline Rmachines
Re: 2 beeps
« Reply #6 on: 17 November 2008, 13:27 »
Yea its low pressure, if the level is low, all the oil in the sump runs away from the pump on a corner and the pump will run dry for a second, it will cause fatal engine failure and fast!  so sort it asap.
As for smoke and drinking alot of oil, if its mornings i would say the valve stem seals are worn out if its constantly smokey it could be the piston rings, if i was you i would top it up, put a bottle of flush in there,  run that and dump the lot out, then fill it with a good oil and filter and add some stop smoke aditive for petrols.  A build up of carbon deposits on the oilways down to the sump will cause oil to build up in the head and drip down the valve stems, therfore, using alot of oil and smoking alot.
Thats the first thing i would try to cure it, Its ok to use the engine like that as long as you keep on top of the oil levels.  :smiley:
Offline barry-gti
Re: 2 beeps
« Reply #7 on: 17 November 2008, 14:16 »
thanks peeps your stars, will get it checked ASAP
Offline ace
Re: 2 beeps
« Reply #8 on: 17 November 2008, 17:38 »
yeah as mentioned its ur oil pressure switch. not that expensive to get £10-£15 from ecp or gsf
