Author Topic: heated seats colour concept  (Read 2133 times)
Offline gti jed
« on: 16 November 2008, 16:20 »
hey i have a colour concept but the drivers heated seat dont work iv checked the fuses and all is ok also changed the switch but no difference any ideas on what i should try next??? cheers jed
Offline alexus1981
Re: heated seats colour concept
« Reply #1 on: 16 November 2008, 20:07 »
hey, i've got a concept with a faulty passenger leather seat heater, mine (the drivers one obviously) works a treat (infact its a little too hot for me) i havnt had the passenger one fixed as i never sit in the passenger seat. my gf constantly moans about it as she's always cold (typical woman), aparently the actual bit that should get hot needs replacing. costs about £20ish plus fitting so i've been told.
yOuR mUm...
Offline eightyeightmph
« Reply #2 on: 17 November 2008, 20:08 »
Yep, it'll be the pads in the seat. Last ones on ebay where about £30 ea. Don't know where you can still get them tbh?
2016 GOLF GTD
kells
« Reply #3 on: 17 November 2008, 20:37 »
you can get the heated element pads from the dealers
Recaro leather part no: 535 963 555C
Non Recaro  leather seat part no: 1H0 963 555B
 both around 71 quid each.. this is for the bottom pads (bits under your arse)
Offline faz186
« Reply #4 on: 18 November 2008, 08:45 »
hey guys
i have an r reg vr and my prob is that they dont get hot enough, i turn them to max and they only get litle bit hot, does any1 know what is the cause of mine not heating up, i know that they are supposed to get realy hot coz my mates do in his vr,
would i need to change the heating pads or is it a switch problem
p.s. when you turn the number up does the switch make a ticking noise evrytime you change up a number, coz mine doesnt?
thanks
faz
« Reply #5 on: 18 November 2008, 09:45 »
Switch sounds normal, mine doesn't click anyway? :huh:
Have you checked the relay under the seat? Does sound like you need new pads anyway - they are made up of a thin wire track & the wire, like a fuse, burns out over time so less & less of the pad actually heats up.
£71 ea!  :shocked:
Think I'll just stick with a cold bum for now! :grin:
2016 GOLF GTD
VeeDubClub
« Reply #6 on: 18 November 2008, 09:57 »
Jed mate.. steal the one from the passenger side and make your passenger have a cold arse!
Orr.. just leave it for now, when its cold we can go in my car as mine work  :tongue:
Offline green-blood
« Reply #7 on: 18 November 2008, 12:03 »
mine dont budge at all.. but no on can tell me what fuse/relay to check
anyone any ideas?
« Reply #8 on: 18 November 2008, 12:06 »
anyone any ideas?
Under the seats there's a relay attached to the subframe, easiest way is to just drop the seat out!
2016 GOLF GTD
Offline green-blood
« Reply #9 on: 18 November 2008, 12:30 »
aha,,,cheers
so no other fuses??
