Author Topic: Leaky MK2 16V  (Read 1266 times)
Offline Redcap
Leaky MK2 16V
« on: 02 June 2004, 11:39 »
I have a serious problem with my 16v leaking oil! I am stripping the top end and replacing gaskets etc. However, I have oil leaking into my distributor cap! What the bl***y h**l is going on?
Any helpfull suggestions or possible causes / solution please! Also, any general tips whilst I am doing this work would be much appreciated!
Mk2 Gti 16v (1989)
Thanks
Redcap ???
Its a GTi
Offline Gambit
Re:Leaky MK2 16V
« Reply #1 on: 02 June 2004, 12:09 »
its the inner oil seal in the dizzy itself
you cant get these from VW but if you go to a bosch specialist and ask them for a 12.5mm seal, you can getaway with using a 12mm seal if the pinion is pretty worn
« Last Edit: 02 June 2004, 17:16 by Gambit »
