Author Topic: A wet day at Colerne  (Read 6979 times)
Offline Paul86S2
« on: 15 November 2008, 16:12 »
Took the Golf (Mk 3 16v) to Colerne Airfield day last monday and it rained most of the day.
The track was soaking with standing water in a lot of places, they shut off the main straights for most of the day due to standing water and the need to reduce speeds a bit.
Made a nice change to be able to beat the big HP rear wheel drive cars around the circuit, they just couldn't get the power down. Most of the hot hatches were still belting around, big benefits for front wheel drive in those conditions.
The Golf performed admirably all day, 13 sessions completed and two spin outs. The car was wheelspinning in second out of the tight corners so perhaps need to think about some more negative camber on the front, also getting some wheelspin going up into third on the straights due to the massive amounts of water.
The best fun on the circuit was a lazy left hander taken about 60 in third, running wide on the exit under full acceleration and then hitting the water running across the track. You could feel all 4 wheels give up grip sliding sideways with the front wheels spinning and then you would gain traction and lurch forward with the back end twitching. Slightly unsettling the first few times but it became addictive for the rest of the day.
The back end on the Golf seems to be very unpredictable, you can get it to twitch out of the corners but once it lets go you are just a passenger, nothing progressive in it at all.
The exhaust rubbers have stretched again so had to put up with the exhaust knocking on the tight corners, they've lasted about 10 trackdays so not too bad.
Off to Abingdon in December for the last trackday of this year so will get the new exhaust rubbers put on and adjust the front camber.
Paul
VeeDubGTI16v
Re: A wet day at Colerne
« Reply #1 on: 15 November 2008, 18:15 »
it evens the field when it rains doesnt it, porsches are easy prey!
my golf feels very twitchy in the rain as well, are you running big arb's? i think this is my problem.
Offline Paul86S2
« Reply #2 on: 16 November 2008, 13:30 »
Yes definately slows the big boys down, and p!sses them off when you come past them.
I'm running standard ARB's at the moment but thinking of investing in some. Did you find a big improvement?
Paul
VeeDubGTI16v
« Reply #3 on: 16 November 2008, 19:29 »
yep, worth every penny
Offline danny_p
« Reply #4 on: 30 November 2008, 13:09 »
stiffen the back right up,  they become very chuckable
all the VW's have gone bar 1.
Offline jacko16v
« Reply #5 on: 30 November 2008, 19:39 »
What brand you running? Looking for some at the moment for my track slag
VeeDubGTI16v
« Reply #6 on: 30 November 2008, 22:52 »
the biggest i found (for mk2) were the neuspeed and h&r  arb's at 25mm front and 28mm rear. i went for the h&r as they were cheaper!
Offline danny_p
« Reply #7 on: 01 December 2008, 01:11 »
i made an arb off something else fit on one of my old golfs it made a hell of a differance  :smiley:
would think some of the kits avalible now would ( should ) do a better job  one i fitted was 30 ish mm made things a bit intresting in the wet
Offline jacko16v
« Reply #8 on: 05 December 2008, 21:27 »
Got any pics of the one you made? Wouldnt mind having ago my self...
