Author Topic: Power Steering Pump & water pump?  (Read 1586 times)
Offline eightyeightmph
« on: 14 November 2008, 13:36 »
Mine have both about had it, Jodie at Midland has quoted to do them when he does the camber/tracking after I fit the coilies, but I was wondering if anyone has done either themselves & where/who supplied the pumps?
Thanks!
2016 GOLF GTD
Offline jafo
Re: Power Steering Pump & water pump?
« Reply #1 on: 14 November 2008, 14:52 »
I did my waterpump myself on my vr, its not a hard job, the parts i got from GSF and they were spot on! Pump and belt cost me less than £30!
Not a hard job on the vr, requires loosening engine mount and jacking the engine up to make it accesable though.
And i guess your power steering pump will be in the same place as my vr and i need a new one too, i got one priced up last week with GSF iirc they quoted me £65.
Hope this helps
« Reply #2 on: 14 November 2008, 15:21 »
Thanks! It's annoying as I only put on a new radiator earlier in the year & had I known about the pump at the time I could of done it at the same time! :rolleyes:
Thanks for the info re. prices though, spot on! :afro:
2016 GOLF GTD
Offline davero
« Reply #3 on: 14 November 2008, 16:58 »
Power steering pump is very easy to do, just two or three bolts. Did it on my old 16v
« Reply #4 on: 14 November 2008, 17:08 »
I'll have a look in the old haynes manual then!!
2016 GOLF GTD
Offline bored_Welsh_lad
« Reply #5 on: 14 November 2008, 23:01 »
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
« Reply #6 on: 15 November 2008, 01:28 »
any good to you my dear friend..
http://faculty.ccp.edu/faculty/dreed/Campingart/jettatech/t-belt/index.htm
Niiice! Cheers dude, not sure if I can afford to do it myself, Hoegardden is expensive!! ;)
2016 GOLF GTD
