Author Topic: Mk2 golf Gti gearbox  (Read 1038 times)
Offline simpleton
« on: 13 November 2008, 09:24 »
A few years back my gearbox failed and had it replaced,but since then it doesnt go as fast ie the revs in the gear are shorter?
i asked the garage who changed it if it was a origional gti gearbox thery changed it wirth and they said yes.
how can i check if it is a gti or not just a 5 speed driver etc.
thanks
Offline Khare
  • The bear that khares
Re: Mk2 golf Gti gearbox
« Reply #1 on: 13 November 2008, 10:53 »
theres a code under the gearbox, post it up on here and someone will be able to tell you what gearbox it is.
« Reply #2 on: 13 November 2008, 11:47 »
which gears in particular, or is it in all gears?
Offline simpleton
« Reply #3 on: 13 November 2008, 11:57 »
1st is quite long 2nd is short 3rd is ok 4th and 5th short
« Reply #4 on: 13 November 2008, 12:46 »
hmm i wonder if you have a 16v box, did they put a new clutch on it too?  best thing to do is check the box code though really!
Offline simpleton
« Reply #5 on: 14 November 2008, 09:16 »
yes new cluctch fitted at the same time.
