Author Topic: dynamat to quieten down exhaust  (Read 1642 times)
Offline paultownsend
« on: 12 November 2008, 13:37 »
my milltek is loud. esp so after the new engine.
i spent yesterday with my bike in the boot, parcel shelf out, and seats down. and its soo much louder.
so will adding some dynamat type sound deadening quiet things down a little. most the sound seems to be coming through the boot floor!
Offline Diamond Hell
  • Opinions я Us
Re: dynamat to quieten down exhaust
« Reply #1 on: 12 November 2008, 15:50 »
Put a less ghey back box on it and don't put dynaleadmatting into it, thus saving weight and maintaining performance.
nige_s
« Reply #2 on: 12 November 2008, 15:52 »
+1
sharpie
« Reply #3 on: 12 November 2008, 18:15 »
+1 for spelling of ghey
Offline Benrevs
« Reply #4 on: 12 November 2008, 18:19 »
That spelling of gay was taxed, I noted dh's appreciation of it a while back :wink:
« Reply #5 on: 13 November 2008, 00:35 »
ghey back box? the difference the full milltek exhaust made from a brand new oe vw system was night and day. i bought the vw system because the milltek was too loud. but it would not let me pull in higher gears. at all.  the 2.0 8v gives storming pull between 70-100 in 4th. and it killed it!
the milltek is also a odd bore size, and not compatible with other aftermarket stuff
  • Opinions я Us
« Reply #6 on: 13 November 2008, 08:15 »
Don't be obtuse.  No one's said refit the VAG system.
Most of the tuning of the noise is done on the back box - if you don't like the noise, change the back box.
Don't try telling us that you couldn't possibly change the exhaust either - anyone with a grinder and a welder can make whatever changes they want to an exhaust.
I very much doubt that Milltek use their own custom drawn, uniquely sized tubing for their Golf2 exhausts.  If you've not found an alternate back that fits then you've just not looked hard enough.  You could always use a reducer or enlarger section in the exhaust, if you can't weld.
Have you spoken to Milltek about the problem?  You may well find that they can provide a quiet-pack rear silencer anyway.
Lead matting is definitely not the answer.
« Reply #7 on: 13 November 2008, 14:21 »
its definately over a 2.25 bore, which is over 16v or g60 size. wish id gone for the bl00dy jetex now! probably right about the matting though. it is very heavy.
its strange because on the pb lump it was ok. its only after the 2.0, bigger ex valves etc, its gotten worse. emissions are dandy though. just assume its kicking a little more gas out
  • Opinions я Us
« Reply #8 on: 13 November 2008, 16:41 »
Ya think?
Possibly this is your issue - far more gasses exiting in a far more enthusiastic manner.
Plus it's tuned to sound 'bad-assed'.
Offline dubmaster77
  • actualy on the road!
« Reply #9 on: 13 November 2008, 17:01 »
Miltek do two sytstems normally one with a centre box the other without? Do you know which system you have??  they also tend to be much Higher quality than other systems, Im still saving for mine!!  :nerd:
K-Jet is my friend!
