Author Topic: Water pump?  (Read 823 times)
Offline claire.major
Water pump?
« on: 11 November 2008, 20:28 »
Hi, after a split coolant pipe the water is now not circulating the engine and its developed a rattle/knock from engine! Water pump failure? help wld b mega, thanx
Offline Conker
Re: Water pump?
« Reply #1 on: 11 November 2008, 20:30 »
Much more likely to be an air lock around the water pump.
Offline Conker
Re: Water pump?
« Reply #2 on: 11 November 2008, 20:33 »
Lots of squeezing pipes required, having the heater on hot doesn't matter apparently but it can't hurt either, I find over filling the expansion tank also helps push air out (so long as you drain the excess water out afterwards if it doesn't all go into the system). Rev the engine every now and again etc.
If you still can't see a jet of water firing into the top of the expansion tank and the noise doesn't go away then suspect the pump.
Re: Water pump?
« Reply #3 on: 11 November 2008, 21:43 »
coolant faq, in the mk2 section :)
