Author Topic: Mk3 Engine Mounts - Solid or not  (Read 975 times)
Offline Paul86S2
« on: 11 November 2008, 19:11 »
I'm looking to replace the engine mounts on my Mk3 16v track car. They are all a bit past their best.
Has anyone got any recommendations. I've read a bit about fitting a solid front one and leave the other two standard.
Paul
Offline maximous
Re: Mk3 Engine Mounts - Solid or not
« Reply #1 on: 12 November 2008, 12:52 »
I’ve done this with good results using a machined aluminum block type mount although I’m sure that if you dismantle the standard item removing the necessary material you can weld it thus making a solid mount. If that all sound too much then get a vibratech’s item
