Author Topic: DV Question  (Read 3325 times)
Offline SteveS
  • GTI ED30
DV Question
« on: 10 November 2008, 23:50 »
its been buggin me because... i dont know the answer....
a dv valve. ok, it puts the air back into the intake before the turbo when foot is released from pedal...
blow off valve/spacer... just blows it into the air...
isnt a blow off valve bad for the car? or is it? better to have a dv to recerc the air??  :huh:
SteveS
ED30: Carbonio Intake & Filter | Blueflame TBE | Ebach Sportlines | Neuspeed Torque Arm Insert | Forge DV | REVO Stage2 [353BHP/360lb/ft]
Offline ub7rm
Re: DV Question
« Reply #1 on: 11 November 2008, 07:38 »
AFAIK a blow off is bad because the various sensors are aware that a certain mass of air has entered the system, and if its just blown off to atmosphere it appears to the ECU that this air has just vanished so you might get error codes indicating a boost leak or similar.
I know that people fit the blow of valve to the 1.8T's and they seem to run OK for a while but then folks have problems when the ECU goes into limp mode.
HTH
2020 BMW 128ti
2017 Golf GTD Estate
Offline AlanD
  • MK5 2.0T 16v
Re: DV Question
« Reply #2 on: 11 November 2008, 09:06 »
To my knowledge the only thing a blow off valve does is make your car sound like a Scooby :rolleyes:
Offline SteveS
  • GTI ED30
Re: DV Question
« Reply #3 on: 11 November 2008, 15:26 »
i know they just make a sound, but wasnt sure if they actually affect the car...
i know the MAS monitors the air from the intake... but if the dv just drops the air, how would it know?
SteveS
Offline vRStu
Re: DV Question
« Reply #4 on: 11 November 2008, 18:02 »
Any air after the MAF is metered, either by the MAF itself or the MAP (Manifold Absolute Pressure) sensor.  Some cars deal with the loss of the pressure better than others and the more common reason for a VTA (Vent to Atmosphere) type valve is to alleviate turbo stalling.
1.8T's really don't like it.  The 2.0TFSi isn't so bad but on the TFSi it's nothing more than a noise maker.
Stu
Offline SteveS
  • GTI ED30
Re: DV Question
« Reply #5 on: 11 November 2008, 18:08 »
so it doesnt affect the performance or errors? i know it wont do anything but noise.. just curious.
SteveS
Offline SteveS
  • GTI ED30
Re: DV Question
« Reply #6 on: 12 November 2008, 19:03 »
SteveS
Offline neg
Re: DV Question
« Reply #7 on: 12 November 2008, 21:41 »
It has something to do with putting air back to the turbo to keep it spinning so when you back on boost it can react quicker, dumping air out means the turbo will have to spin up again wasting time/power - something like that anyway...
Plainly the 1.8T and 2.0T have been designed to re-circ the air unlike other TC'd cars so its best to keep it that way.
Offline RedRobin
Re: DV Question
« Reply #8 on: 12 November 2008, 21:51 »
....Exactly! Isn't it even called a Recirculating Valve now?
Offline SteveS
  • GTI ED30
Re: DV Question
« Reply #9 on: 13 November 2008, 21:06 »
I understand, however DOES it ACTUALLY keep the turbo spinning, if its just put back into the intake, then its not exactly pushed into the turbo to keep it spinning....  i know thats the idea, but is it fact!
SteveS
