Author Topic: Starter Motors  (Read 729 times)
Offline Dec
Starter Motors
« on: 10 November 2008, 22:00 »
My starter motor is on its way out (i think its that anyway) It turns over a few times then just makes a wierd electric type noise. After a few quick turns of the key it starts. The starter motor was a bit dodgy when I brought the car and had to clean it out then so i think its finally giving up.
My question is... Will an 8v GTI starter motor work on my 1.6 Driver?
My mates got one he said I can have cheap if it will!
Thanks,
Dec
Offline Conker
Re: Starter Motors
« Reply #1 on: 11 November 2008, 08:07 »
Just a quick one... Have you tried cleaning all the electrical connections from battery to starter motor. You never know...
Offline Village Idiots
Re: Starter Motors
« Reply #2 on: 11 November 2008, 08:41 »
Try connecting it directly from the battery (touching the connector with a jump lead) to check the starter works OK. If it does the problem is elsewhere, maybe starter switch or dirty connections.
Re: Starter Motors
« Reply #3 on: 11 November 2008, 12:35 »
yes a GTI starter will work on your 1.6, any 020 gearbox one will, even MK3.  Though the MK3 ones I've seen have a different plug for the trigger wire, the MK2 spade seems to fit on it no bother or you could splice on the MK3 plug end :)
Offline Dec
Re: Starter Motors
« Reply #4 on: 11 November 2008, 21:08 »
Cheers guys! Havent bothered testing it but a year ago when I brought the car it was a bit temperamental and I just "refurbed" it.
Picking up one from my mate tomorrow so will see how it goes!
Thanks,
Dec
