Author Topic: VAG COM software results  (Read 2449 times)
Offline papperbear
  • Ding Dang Doo ...!
« on: 01 June 2004, 10:40 »
Friend of mine has the VAG COM software and he plugged it into my MKIV over the weekend with the following results, I know there are a couple of faults but could someone help me with part numbers and ideas of what they mean?
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01: Engine
   Controller: 06A 906 018 CG
   Component: 1.8L R4/5VT MOTR HS D02
   Coding: 04000
   Shop #: WSC 00028
2 Faults Found:
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
            P0116 - 35-00 - -
00544 - Maximum Boost Pressure Exceeded
            35-10 - - - Intermittent
Readiness: N/A
Address 03: ABS Brakes
   Controller: 1J0 907 379 Q
   Component: ABS/EDS 20 IE CAN  0001
   Coding: 13504
   Shop #: WSC 00028
No fault code found.
Address 08: Auto HVAC
   Controller: 3B2 907 044 C
   Component: CLIMATRONIC     C 0.7.0
   Coding: 01000
   Shop #: WSC 00028
2 Faults Found:
00792 - A/C Pressure Switch (F129)
            35-00 - -
01272 - Positioning Motor for Central Flap (V70)
            37-10 - Faulty - Intermittent
Skipping Address 15-Airbags
Address 17: Instruments
   Controller: 1J0 920 921 A
   Component: A4-KOMBIINSTR. VDO V22
   Coding: 05442
   Shop #: WSC 00604
   IMMO-IDENTNR: VWZ7Z0X1897667
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
            30-10 - Open or Short to B+ - Intermittent
Address 19: CAN Gateway
   Controller: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 00028
Address 46: Central Conv.
   Controller: 1J0 959 799 AH
   Component: 4H Zentral-SG Komf. 0001
   Coding: 00257
   Shop #: WSC 00028
3 Faults Found:
01179 - Incorrect Key Programming
            35-00 - -
00943 - Heated Exterior Mirror: Driver Side (Z4)
            35-00 - -
00944 - Heated Exterior Mirror: Passenger Side (Z5)
            35-00 - -
End   ------------------------------------------------------------------------------------
Offline Dizzie
  • Make friends with your fast
Re:VAG COM software results
« Reply #1 on: 01 June 2004, 13:24 »
it means now you can worry about all those things that you thought were alright  ;)
Mk4 Golf 150PD
kniterider
« Reply #2 on: 03 June 2004, 11:25 »
must get that vagcom lead ive been promising my self very soon! ive got sooo much vw software already on my laptop for the v.a.g range im kicking me self cause until you have the lead you cant even playwith the software properly!!, as for your fault codes im not 100% sure, goto the vagcom section on ukm4's site and thelly help you in an instant!
just took my 20v gti back to the garage today as it was sooo underpowered since rebuild, took em 20 mins to show me i had 'sensor g60' or was it 'g40' any way this is the inlet camshaft sensor so i drove it away got me spare what i had from spare head discconnected battery for 1/2 hour then bingo! back on form.... going to look for a lead and convertor now!!!.. ill see if i can find out what them faults all mean etc for yas
Gaz 8)
Offline papperbear
« Reply #3 on: 03 June 2004, 19:05 »
Cheers,
I've found one of the fault codes that relates to the Climatic control - I need to get it re-gassed.  VW main stealer wanted ?105 so I'm looking around Southport for local VW specialists.
Will let you know how I get on ... perhaps we should have a VAG com section on the forum?
Offline topher
  • Administrator
  • fully functioning
« Reply #4 on: 03 June 2004, 19:09 »
get on google or yell.com and find a specialist AC company, most charge around ?80 and most will come to your house/work to re-gas for you !
