Author Topic: Ashtray problem  (Read 2583 times)
Offline kevy
Ashtray problem
« on: 09 November 2008, 21:58 »
Hi all fellow tdi owners,a few people have recommened this forum to me and in the past everyone has been really helpfull,
My next small but niggly problem is on my mk4 tdi (of course) the ashtray sliding top has come away and after hours of
trying i cannot seem to get in back together properly,i"ve noticed some sort of splined wheel on the underside of the ashtray lid
which i imagine must be what makes it slide smoothly,i"m afraid to admit it but it"s beaten me!!
Any idea"s or hints to help?!?!
many thanks
Kev
Offline Ridg
  • TDI - Soot Happens!
Re: Ashtray problem
« Reply #1 on: 10 November 2008, 10:38 »
when you say the top has come apart, do you mean the sliding lid or the decorative insert which sits on the lid?
as the ashtray lids is made from 2 parts, the piece which sits on the ball bearing runners, and the decorative top (probably wood effect)
the insert slides onto the actually runner part, but the runner part shouldn't come away, best bet is to remove the whole ashtray and take a look.  if you remove the insert (pull toward the back of the car) you'll find a T25 screw undo this, slide the ashtray back and then lift you, the lighter / 12v is connected on the rear, so disconnect this as you remove it.
once you've got the whole unit out it should make more sense.
Offline kevy
Re: Ashtray problem
« Reply #2 on: 15 November 2008, 20:38 »
Thanks for that.  By the way it is the sliding lid that has come off.
Regards Kev
