Author Topic: Very Loud whining noise  (Read 1972 times)
Offline Philpy
« on: 08 November 2008, 17:43 »
On my 16v the engine makes a very loud whining noise, like a bearing, Its not the alternator as I removed the belt and the noise remained. The weird thing is it has made the noise since I have owned it, then the engine went so I put a another engine in, with new cambelt and tensioner, but still get the noise!
The noise goes with the engine revs, and you can here it when my missus is driving it up the road, over the magnex exhaust!  :shocked:
Any ideas?
Oh and I havent got PAS
Offline Khare
  • The bear that khares
Re: Very Loud whining noise
« Reply #1 on: 08 November 2008, 17:48 »
sounds like its gearbox related. Do it only make the noise when in gear? if its in neutral and you rev it does it make it?
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #2 on: 08 November 2008, 18:10 »
Does the note change when you change gear? Also look at some of the plastic shrouding down by the engine pullies. If one of them has been fitted incorrectly, it could be catching on the pullies or belts. :smiley:
Offline Mr Blue
« Reply #3 on: 08 November 2008, 18:40 »
not a 16v g60 engine is it :tongue:
cam belt cover rubbing?
Offline Philpy
« Reply #4 on: 08 November 2008, 18:53 »
Does it when not moving, so def not gearbox releated..
Could a plastic cover make that much noise?
Offline hobbes
« Reply #5 on: 08 November 2008, 19:05 »
i had it with mine.  it was two things, the plate in front of the water pump rubbing on the belt and pulley as well as the cam cover rubbing on a pulley - also not fitted correctly
Mk2 Golf GTI 16v
Mk4 Golf GT TDI
Offline JC
  • Back in the North.
« Reply #6 on: 08 November 2008, 20:36 »
erm, its been there for 2 engines   :undecided:
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
« Reply #7 on: 08 November 2008, 20:40 »
clutch release bearing?
Offline Mr Blue
« Reply #8 on: 08 November 2008, 20:49 »
the misses?
Offline danny_p
« Reply #9 on: 09 November 2008, 01:19 »
all the VW's have gone bar 1.
