Author Topic: Diafram ?  (Read 2427 times)
Offline AmiLady
Diafram ?
« on: 04 November 2008, 15:55 »
hello all need a lil help with a small problem im having
my cab has started idleing high and low when reversing and waiting in traffic and have narrowed it down to be the diafram
but finding 1 is proving hard
any1 know anywhere ?
want a new 1 really but used will do
Re: Diafram ?
« Reply #1 on: 04 November 2008, 16:08 »
diapham?
Offline wayders
  • Built by the germans, thrashed by the british!
Re: Diafram ?
« Reply #2 on: 04 November 2008, 18:28 »
Thought ladies knew about where to find a diapham lol!  :smug: :smug:
Offline AmiLady
Re: Diafram ?
« Reply #3 on: 04 November 2008, 20:26 »
ha ha
i only no coz lads r useless
its propper name is a vacuum switch
Offline wayders
Re: Diafram ?
« Reply #4 on: 04 November 2008, 20:39 »
While thumbing through my new Bentley VW A2 manual ('85-'92, GTI, Golf,
>Jetta), I came upon a description of a vacuum/pressure pump that is used to
>actuate the automatic door and trunk locks. Seems to include a
>pressure/vacuum switch, and is encased in a thick foam block for shock and
>noise dampening.
Found this whilst browsing......................  :kiss: :kiss:
Re: Diafram ?
« Reply #5 on: 05 November 2008, 12:16 »
ah i think i know what you mean, does it have a hose out of each end and an electrical plug on it? in the engine bay somewhere?  if so i found one of these the other day, cant tell you if it works though! if the brackets are what you want i'll throw it in the box with em :)
Offline AmiLady
Re: Diafram ?
« Reply #6 on: 05 November 2008, 23:14 »
ur rite on the button
thats the part
still need to see the pics of the brackets as my hood was lecci but the hodd has been replaced and not linked back up
and missing some bars to pull the hood back but its nothing off the main frame as the hood does go down by hand
just the lecci rams are not linked up
Re: Diafram ?
« Reply #7 on: 06 November 2008, 10:38 »
Ah no thats not the part I was on about! That is the cold mixture enrichment vacuum switch, it makes the 5th injector spray a bit of fuel when cold and you pull away sharply.  I wouldnt have thought it would cause those symptoms though?  disconnect the plug off it, see if it improves.  Those are more common to find on 16vs, as only the late k-jet 8vs got them!
Offline AmiLady
Re: Diafram ?
« Reply #8 on: 06 November 2008, 20:07 »
yeah took the pipe off and impoves loads
so still lookin lol
Offline AmiLady
Re: Diafram ?
« Reply #9 on: 09 November 2008, 20:36 »
all sorted now thanx very much  :grin:
