Author Topic: So how does a Carbonio work?  (Read 8538 times)
Offline GtiJames
Re: So how does a Carbonio work?
« Reply #20 on: 04 November 2008, 13:23 »
[/quote]
you won't get 10bhp from an induction kit.
[/quote]
coupled with full milltek and stage 2 chip i can see it been close to that amount
and:
http://www.vag-tuner.com/extras/Vflowtfsi.pdf
Offline gazbutmk5gti
« Reply #21 on: 04 November 2008, 17:41 »
don't bight, he doesn't understand these things can make a much bigger difference on a turbo charged car :smiley:
Revo stg2+ & lots more
Offline barnesy2004
« Reply #22 on: 04 November 2008, 20:40 »
hi there, how much u looking for ur carbonio??
cheers mark
Offline jamiekip
« Reply #23 on: 04 November 2008, 20:59 »
You have mail  :smiley:
Offline duffy78
« Reply #24 on: 05 November 2008, 09:12 »
[/quote]
and:
[/quote]
that surprises me,
I always thought that naturally aspirated engines gain the most from induction kits, due to the denser cold air being fed into the system, id have thought that any increased airflow would be minimal in a forced induction car, and the cold air thiing goes out the window as soon as the air hits the turbo and rapidly increases in temp.
Offline jamiekip
« Reply #25 on: 05 November 2008, 16:31 »
A load of the S3 guys have seen 15bhp with a CAI.
The Carbonio helps mid range response and torque, but not a lot else.
If you want power, you're looking at and EVOMs, Nuespeed, Forge or Dibilis paired with a milltek or something.
You'd see 25-30bhp with that alone!
Offline barnesy2004
« Reply #26 on: 05 November 2008, 18:58 »
hi mate its markbarnes2004@hotmail.co.uk, is it a genuine carbonio? how old is it? also is it in good condition? cheers mark
sharpie
« Reply #27 on: 05 November 2008, 22:03 »
and:
you seem to have mucked up the quotes.
yes, combined with a full manifold and exhaust system and a remap then i'd expect power gains in that region. not from an induction kit alone. too many idiots believe the hype on the boxes.
Offline k4ith
« Reply #28 on: 05 November 2008, 22:32 »
im looking into a new intake at the mo, seems like quite a cheap mod to get an extra 10bhp and a bit more torque, torn between dbilas and EVOMS one, both around £300 mark, dbilas looks better but like the heat sheild and an engien cover you can get with EVOMS, anyone know if i buy the dbilas will the evoms heatshield and engine cover fit?
thanks
Yes they do, I was/am going to get the heatshield, the engine cover is a waste of cash imo, save the weight lol! how often do you look under the bonnet of your car?
MKV Golf GTI Edition30, GIAC Pump&Race Map, AutoTech Fuel Pump, R32 Front Brakes, Dbilas Flo-master Intake, S3 Intercooler.ECS Dog Bone Insert.
MKII GTI 8v Tornado Red 88 - Das Projekt
Offline RedRobin
« Reply #29 on: 05 November 2008, 23:36 »
^ At shows etc other people look under my bonnet quite often.
But apart from that, an engine cover actually helps protect the engine from water and dirt etc.
« Last Edit: 05 November 2008, 23:38 by RedRobin »
