Author Topic: replacing rear shocks  (Read 582 times)
Offline lozp
« on: 03 November 2008, 12:35 »
 hi
  my 1991 golf driver just failed its MOT due to the offside shock leaking. how easy is it to replace them?? (i am fairly mechanicly mined and dont mind getting my hands dirty) what tools would i need there are springs arround the shock so i guess i need a spring compressor?? is there any good guides on the interent on how to do this?
cheers
Offline DarnPB
  • Formerly Darnpistonbroke
Re: replacing rear shocks
« Reply #1 on: 03 November 2008, 12:52 »
Very easy and you will not need a spring compressor. You do need one for the fronts.
You will need to remove the speaker shelf from the offending side to get easy access to the top of the mount. (The plastic bit that the seat belt routes through.)
Its a basic spanners, remove and refit job. I can do one side in 30 minutes, so it must be easy. It would be a good idea to replace both rears as a pair and also the foam or rubber insert that are fitted over the piston rod of the shock absorber.
