Author Topic: Headlight adjustment  (Read 906 times)
Offline richieboy
« on: 03 November 2008, 08:17 »
Hi there, just wondered if any of you would know how to adjust the headlight beam height, the problem i am having is that i have electric height adjusters on the back of the headlights but i dont have the electrics to run them  :sad: so is there a way of manually doing this or am i going to need a new set of headlights?
Thanks in advance
« Last Edit: 03 November 2008, 10:18 by richieboy »
Offline richieboy
Re: Headlight adjustment
« Reply #1 on: 20 November 2008, 08:19 »
So, the adjusters are there just very hard to see as they are tucked away in the wing. Now i just have to get to them  :grin:
« Reply #2 on: 20 November 2008, 09:11 »
Mine have 2 adjusters one inside the wing and one closer to the radiator, I would think you need to remove the headlamp to adjust the one inside the wing.
Offline wessels
« Reply #3 on: 22 November 2008, 09:57 »
If you stand in front of headlights youll see there is a hole on the fender side above the headlight a large phillips screwdriver or flat and youll be able to adjust the height of the light the inside adjuster does the horizontal
